Question about HP Compaq nx6110 Notebook
256 MB DIMM#1(DDR333) UPGRADE TO 2GB RAM in compaq nx6110 pc notebook
    Sergeant:
    Champion:
  • 212 Answers
You should be able to upgrade to 2 gig. Here are specs. Good Luck.
512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
  • RAM configuration features 2 x 256 MB
  • Posted on Nov 20, 2009
    RAM upgrade
    (1) flip the Notebook/Laptop PC over - see Fig.1 below
    (2) find the memory cover - it really easy to find in this photo.
    Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
    (3) remove the (1) screw securing the memory cover.
    Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
    The RAM (SO-DIMM boards) are visible at center left.
    The HDD cover is seen at the bottom of the photo.
    (4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
    (5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
    Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
    (6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
    (7) reassemble system, and boot OS (operating system).
    The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
    (8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
    The technology of the Toshiba Satellite M35X-S349 memory module is called
    DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
    The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
    Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
    Reference: http://en.wikipedia.org/wiki/SO-DIMM
    Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
    The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
    Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
    in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
    Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
    Hi I have an NEC KW300 laptop, it currently has a duel core 2 processor with 2ghz, it has 1gb ram at the moment. I want to upgrade it now with a 2gb ram. Do you have any idea if those laptops has a DDR2...
    Hmmm, something does not appear correct. The Crucial memory selector indicates that the Versa Premium will hold 2 256 MB DIMM for a total of 512 MB.
    http://www.crucial.com/store/listparts.aspx?model=Versa%20Premium%20Series&Cat=RAM
    Aug 15, 2011 | NEC Versa Premium Notebook
    I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
    Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
    One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
    Please rate this reply - good luck!
    Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
    Hp Compaq dx2200 MT RAM Problems
    Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
    Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
    I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
    Make sure that you got the right memory module with this specs:
    Memory
    • DDR266 (266 MHz) so-DIMM 200 pin
    • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
    or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
    there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
    You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
    Phone Support (Direct to Service Desk)
    1-800-8FUJITS (1-800-838-5487)
    Available 24 hours, 7 days a week.
    Consumer Sales - 1-800-FUJITSU
    Corporate Sales - 1-800-831-3183
    Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
    -ERNZ
    Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
    Just need to know how to change the ram in my Sony Vaio PCG-v505ap
    visit vaio manual in
    ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/
    You can do this in two ways: opening your notebook and taking a look on the memory modules already installed (we will explain more about this later) or running a program like Everest (available on our download section). We ran Everest (going to Motherboard, Chipset, Memory Slots) on our notebook and found that it was using two 256 MB DDR-SDRAM PC2700 (“DDR333”) modules, for a total of 512 MB.
    imageview.php?image=1680
    click to enlarge
    Figure 1: Checking your current memory configuration with Everest.
    If your notebook has an empty memory slot, just go to the computer store and buy a new SO-DIMM module with the same technology (SDRAM or DDR-SDRAM) and speed of any capacity you want – of course you need to know the capacity limit of your notebook. You cannot install a 1 GB module in a notebook that only accepts modules up to 512 MB, for example. Our notebook – a Sony Vaio PCG-V505ECP – accepts modules up to 1 GB, for a total of 2 GB RAM, since it has two memory slots.
    For example, if your notebook has one 256 MB module and an empty memory slot, if you buy and install another 256 MB module, it will have 512 MB RAM. If you buy and install a 512 MB module, your notebook will have 768 MB.
    If your notebook already has two memory modules, you will need to remove one of the installed modules in order to install the new one. If the two modules have the same capacity, it doesn’t matter which one you will take away, but if they have different capacities, remove the one with smaller capacity. The new RAM capacity of your notebook will be of the capacity of the remaining module plus the capacity of the new module.
    In our case, our notebook has two 256 MB modules. So we will remove one of these modules and install a new one on its place. We bought a 1 GB-module, so after installing it our notebook will have 1,280 MB RAM installed (memory math is tricky, since 1 GB equals to 1,024 MB not 1,000; so 1,024 MB + 256 MB = 1,280 MB).
    else visit
    http://www.hardwaresecrets.com/article/189/1
    Jul 02, 2009 | Sony VAIO PCG-V505DXP Notebook
    Not enough memory
    • your Toshiba Satellite M35X-S311 has the following memory configuration
    • Configured with 512MB
    • The maximum memory you can have is 2048MB (Max),
    • 2 memory slots using 1024MB PC2700 DDR333 SDRAM 2.5V SODIMM Memory modules (Both slots may be occupied). Go to a store and request for this memory specification and you will have 2GB of memory for all the programs you have listed here. Good Luck!
    Mar 30, 2009 | Toshiba Satellite M35X-S311 Notebook
    512 MB memory boards do not work in my Fujitsu Lifebook S2020
    frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
    Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
    When i add a memory in damaged DIMM slot showing black screen?
    Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
    Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
    DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
    technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
    B. If additional memory is to be used, install another matched pair of DIMMs
    in DIMM 1 in both Channels A and B.
    Mar 25, 2008 | Intel D865GBF Motherboard
    Ram memory upgrade
    1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
    Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
    HP Compaq nx6110 Notebook Logo
    231 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
