Question about Cameras
There's no usb 2.0 on my computer, I need a download or instructions on how to find it in my registry please!!!!
    Brigadier General:
  • 4,090 Answers
?? if there is no USB 2,0 on your computer then there is no USB 2 It is not a down loadable item If your PC has a USB it is possibly 1.1 but it does not upgrade by download It is a hardware protocol.
It shows in Device manager not the registry
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
Write protected cannot format the usb.
try to remove partition on to disk management tools and make new partition then reformat the USB drive be careful not to delete the other drive.. or use a software that can manage drives like paragon or acronis partition manager .
Aug 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protected
The problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have problem in my transcend usb 8gb pandrive that i can't copy or delete any ting from pandrive. error is drive is write protected or can't format. please give solution
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
Jan 07, 2011 | Transcend Electronics - Others
MY PENDRIVE HAVE ONE PROBLEM( COPY WRITE MUST BE PROTECTED ) PLEASE REMOVE THE WRITE PROTECTION
1. Click Start > Click Run, type regedit and press Enter, this will open the registry editor.
Download this batch file called add.bat, and double click after download the key will be automatically added to registry.
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. Check
In case you still find an issue, please let know me.
Oct 28, 2010 | Computers & Internet
My 4gb pen drive can not format help me
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
In case you still find an issue, please let me know.
Oct 27, 2010 | Kingston 4GB Secure Digital High Capacity...
How can I remove write protect from my USB flash?
Oct 17, 2010 | Computers & Internet
My 2.0 memory card used by my usb need to remove a write protection how can i remove a write protection on it? please help me..thanks
Oct 17, 2010 | Cameras
When i copy a kind of file to my 4gb kingston data traveler it say "the device is write-protection or another disk solve this problem please please
Hi Friend,
Please make sure that the physical lock (if provided on the pen drive) is properly unlocked.
After doing that, kindly follow the steps:
1.Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2.Navigate to the following path:
If the registry key StorageDevicePolicies key does not exist, you will need to create it. To create and download the batch file add.bat please click the link below
http://www.troublefixers.com/wp-content/uploads/Miscellaneous/add.bat
3.and double click after download the key will be automatically added to registry.
4.Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
5.. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer.
I hope this will resolve the issue.
Regards
Chiranjeet
Sep 16, 2010 | Computers & Internet
USB drivers
go to your manufacturer's web(dell,gateway,hp) site and download the latest chipset for your particular computer and operating system.
that should do it for you,
good luck please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Installation of a downloaded driver for Lexmark X1290 All-In_One
I bought a Lexmark X1290 printer and installed a wrong driver (for WinXP) from the enclosed CD. Then I could not run the All in One program. After many reinstallation attemps, I finally found a solution (which is unfortunately quite hidden at the Lexmark website):
1) Unplug the printer's USB cable from the computer.
2) Download the cleaning utility from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/.
3) Double-click on the cleanup utility and follow the on-screen instructions to run it.
4) Restart the computer.
5) Download all files from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/reg/
6) Follow the instructions in the "Vista BackDoor Instructions.txt" and delete all remaining Lexmark
keys in the registry.
7) Restart the computer
8) Download a proper driver for Windows Vista from the Lexmark website.
9) Install the driver accordingly to the instructions (it's important to plug the printer's USB cable when you are ask to, not before)
The problem with Lexmark Unistall and CleanUp Utility is that you cannot delete all Lexmark registry keys while you arelogged in the system. This is anellegant way how to circumvent the problem.
Mar 05, 2008 | Lexmark X1290 All-In-One InkJet Printer
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
