Parts for split mini air conditioner external unit
Need external unit housing components (parts) for a Soleus KFR-12WD, i.e., dextral cover, cover, faceplate combo, sponge combo and pedestal combo.
  • 589 Answers
You may be able to contact Soleus here:
http://www.soleusair.com/Contact/contact.htm
Posted on Jan 11, 2008
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Outside unit freezing
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
My mini split only sometimes responds to the remote
indoor pcb in the indoor unit faulty and the responder.
Jun 09, 2009 | Soleus KFR-18GW Split System Air...
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Soleus KFR-18 Air Conditioner Problem
Check your thermostat settings at heat mode.
Jan 03, 2008 | Soleus KFR-18 Air Conditioner
Replacing squirrel cage blower
You have to take blower out by removing the 2 screws that is holding it ,then you loose the motor shaft from wheel by using a Allen key .Once motor shaft is loose you then loosen motor frame from housing and slide motor out .Might have to spray it with wd 40 .
On the housing should be some screws along the side so you loosen those and house ing would open up so you can get wheel out.
To install you reverse the process.
Please note the direction of the old wheel because if install backwards will not work right
Feb 14, 2018 | Soleus Mini Split 12000 BTU A/C Air...
Heating & Cooling Logo
223 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
