Kelvunator kw40cw i need to know how to use a kelvinator kw40cw washing machine
4 Suggested Answers
  • 1294 Answers
SOURCE: User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Posted on Dec 26, 2007
blueextc3221
  • 15935 Answers
SOURCE: do you have the manual of the kelvinator washing machine 380 ?
www.diplodocs.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
caroldon
  • 17130 Answers
SOURCE: My Kelvinator Washing Machine lets
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jul 20, 2011
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Sep 30, 2015 | Washing Machines
I have Kelvinator AQUA EXTREME KL600FL lost manual and now dont know how to do the various settings for washing programmes
I am including a link to the kelvinator support center. It seems that KL600FL may not be the complete model number because the site does not answer anything for that number. . Open the lid or door and look around the frame for a model number label.
Support centre
Oct 03, 2014 | Washing Machines
Kelvinator KLC 505
i have kelvinator klc505 washing machine and i need user manual.
Mar 09, 2014 | Washing Machines
My Kelvinator kl 15 tl toplaoder washing machine is very noisy during spin cycles and often becomes unbalanced.
if the noise is a rumble, then you have bearings failing. if it's a clunking then you have an issue with the springs. springs you can replace yourself, bearing / seal replacement is a little more in depth.
Jun 22, 2013 | Kelvinator Washing Machines
Kelvinator Smart Drive 058 and I think the filter needs clearing
Hi there.... I don't have a solution but we have the same problem! If anyone is reading this and know the answer, you'll definitely be helping two people out!
Jan 28, 2010 | Fisher Washing Machines
Do you have the manual of the kelvinator washing machine 380 ?
www.diplodocs.com
Feb 21, 2009 | Washing Machines
Dec 06, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
