Question about Dell Dimension 3000 PC Desktop
Lights on front right one goes out or blinking what does that mean
  • dcamp77737 Nov 20, 2009
    no the computer is not working well. Seems to be slow and unresponsive I have run for registry errors and norton all clean. I am concerned it maybe a memory issue.
  • Philip Frye
    Philip Frye May 11, 2010
    Is the PC working well. If so I wouldn't worry about the light. Many lights are for A: Power, B: Hard Drive usage C: Standby power Blessings, A/V Media Guy
  • 58 Answers
That should be the hard drive activity light. Its perfectly normal for that that to blink erratically or go out completely at times.
Posted on Nov 20, 2009
Testimonial: "Thanks "
    Sergeant:
  • 295 Answers
Something I think you should try is to download AVG's Spyware free program.
Spyware can greatly slow down your speed of a PC. Norton's and Macafee virus protection also greatly slows down your PC performance also. Amazing they don't tell you this when you purchase it.
Blessings,
A/V Media Guy
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
My Projection Tv - when I turn on it turns right back off no picture no sound ? help
To know where the problem is:
when set shuts off and green power light goes off:
On front of set press and hold both the menu and input buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
May 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv wont turn on green light comes on then goes right out could there be a blown bulb
Do the self check this model has: WHEN GREEN LIGHT COMES ON AND THEN GOES OUT:
On front of set press and hold both the menu and input (device) buttons at the same time and hold both for at least 5 seconds and release both.
Watch the power light, it will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find with a comment here and I will tell you what it means.
SD TECH
Feb 02, 2011 | Mitsubishi WS-55613 55" Rear Projection...
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Turn tv on and turns off right away
Do the self check this model has: when power light comes on and then goes off: on front of set press and hold both the menu and input buttons at the same time and hold both for at least 5 seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it several times.
SD TECH
Oct 19, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Front blinker and run light don't work
Look at the second page of the diagram at the link. The flag "E" in lower right has power coming from the switch. It goes to the instrument cluster, right mirror turn indicator, and right front turn bulb. Is the instrument panel light blinking? How about the mirror? Use these facts to find the break in the wire. If none of these lights is blinking, the switch may be broken, as yadayada indicates. See page 1 at the link. It has a separate contact for the rear light, which is why the back can work and not the front, even though the switch is broken.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=123629
Nov 07, 2017 | 2006 Ford F-150
Flasher
When 1 is inop and the other rapidly blinks that generally means a bad ground to the front light if you can't find it just attach another ground wire to the bulb socket and see if the light blinks normal.
May 27, 2008 | 2000 Mitsubishi Diamante
Dell Dimension 3000 PC Desktop Logo
79 people viewed this question
Alun Cox
