Question about HP Pavilion Elite M9060N PC Desktop
Unable to locate the remote control input location there does not apear to be an input available
  • phil phil May 11, 2010
    what make and model is your computer
  • Philip Frye
    Philip Frye May 11, 2010
    Would you be helpfull in explaining what the remote control would do on this desktop PC? I can not say I've ever heard of a PC with a Remote Control like a TV or VCR/DVD has. Blessings, A/V Media Guy
  • 128 Answers
U need a docking port to configure it rt it will be a seperate piece for thr remote control to work with it usaully will have a usb adapter or a serial plug type setup ...let me know what u find...
Posted on Dec 03, 2009
How can i find the menu ....no button or available remote
If remote is its original one, it should have this button. Sometimes, it might have been marked as 'setup' If the original remote control have no such button, surely the menu button can be located at the front panel of the TV. If the TV has no menu button, and you are trying to select its inputs with a universal remote control, it won't go.
Aug 12, 2013 | Beko Televison & Video
Unable to access Front Input Connectors
If you tell me where you are located I will try to find a seller for your remote. Is the TV a 27F520T 27'' truflat?
Feb 17, 2008 | RCA TruFlat 27F520T 27" TV
Our Sony Tv RMyD003 screen is darker than we would like and we need to brighten the picture. We are unable to locate our Manuel and would need your help. Thank you
Try going to your menu or input select and you should see a scale to darken or lighten input. The remote should have a button on it to let you get to main menu.
Aug 11, 2013 | Sony RMyD003 Remote Control
Sylvania TV lc320ssx keeps switching input modes and won't and cannot stop it. Won't respond to remote or on set controls
Its main system control memory IC is faulty. Replace it. It can be located very near to the main system control IC. Will look like this.5328cc98-0a90-4a81-8aa5-f9c8c2b31484.jpgVery cheap to buy, easly available.
Jun 05, 2013 | Televison & Video
INPUT CODE FOR REMOTE CONTROL T131 TO OPERATE A LG TV MODEL 37LV45OU
Google the model of each to locate possible codes used--also many remotes have a search mode--lets you try one at a time every possible code the remote has built into it.
Please keep in mind that when a different remote is used not all needed features may be available with that remote.
Apr 18, 2012 | Televison & Video
Where's the input keys in the remote control located?
The input key is usually located on the remote, it might also be labeled Source key also. Different manufactures use different labels to label their keys, check the left or right side panel for input/on and off keys as well as source key
Sep 09, 2011 | Sharp LC32L400M TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
We replaced the lamp in our Panasonic PT50LC13 and we still have the blue screen.
if the tv had the lamp blown, probably the screen was totally black.
the blue screen: there is not signal detected.
  • If is any other input available try to search for video or audio.
second: it is critical to know if the menu apears when you call it (front panel or remote control)
Apr 13, 2009 | Panasonic PT-50LC13 50" Rear Projection...
HP Pavilion Elite M9060N PC Desktop Logo
46 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
