Question about Toshiba 57H81 57" Rear Projection Television
57H81 Toshiba Images is blurry and jittery, how can I Fix It
  • 4 more comments
  • Anonymous Feb 10, 2008
    Have a 57" Toshiba Rear Projection that is a bout 5 years old. Almost appears to have a 3-D effect. Blurry and unaligned appearence. Tried the auto focus feature and it show a error. Appears to be the red color that is misaligned. Any ideas and is it worth fixing?
  • nanskwar Feb 21, 2008
    can only watch channels that are hi definition with no problem. All regular channels are jittery and distored. Is it expensive fix?
  • John M Knopp Feb 28, 2008
    My toshiba is starting to get blurry at times but then will right itself. Seems to be very intermitant. Not sure what to do or how to fix.
  • Anonymous Mar 01, 2008
    I have the same problem even after replacing both STK392-180's. The image is extremely distorted when first turned on, but after a warm up of apx. 20 min. the picture attempts to clear up but still has a jittery (if this is a word) image and displays a flashing double image? I did not see any areas on the board that appeared to be hot when the STK's were replaced? Any help would be greatly appreciated.
  • maloneyp Feb 13, 2009
    Where can I find the convergence IC's. I have a Toshiba 57H81. What board and what location are the convergence IC's. What do they look like?
    Thanks very much.
    What is the best way to get to the convergence IC's the Toshiba 57H81 has a big board in front of the chips and the heat sink looks like it's soldered into the main board. Thanks
  • 24 Answers
Go to an unused inut...bring up the menu.....if its clear, its the hyper board........if it blurry......its a convergence problem.
Posted on Jan 11, 2008
    New Friend:
  • 13 Answers
It is a convergence problem: look at my posts on similar convegence problems where 2 integrated circuit ic's (big and black fastened to large heat sink) need to be replaced as well as any resistors that have gotten very hot or have burned open.
Posted on Feb 18, 2008
  • Ken Sheftel
    Ken Sheftel Feb 18, 2008
    spelling is wrong it's an unused INPUT ....BUT THAT IS NOT necessary ...this is a convergence problem guaranteed....and it should be worth fixing IF, that is IF you know what your are doing!!!!....again see my posts on similar convergence problems with big screen (crt projection type) televisions.
  • Ken Sheftel
    Once the repair is finished...run autofocus and all should be well...if not, then full adjustment of convergence using crosshairs and the remote control will be necessary. You must read details on how to do this part replacement especially cleaning away old heat sink compound and applying new heatsink compound as well as other details. Some tv's can be upgraded to the stk392-180 ic's which i highly recommend....others cannot...at least identify and post here the number you see on the ic's spoken of above.
What is an unused inut and how do i get there?
Posted on Feb 10, 2008
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 206 Answers
SOURCE: Toshiba 57H81 Image Problems
This is a common fail for a Toshiba 57H81 the cause most likley is caused by the Hyper board, there are several capacitors that have weakened and need to be replaced, these are surface mounted and have VERY Fragile contact points, if your soldering skills are week you might want to take this somwhere to have it fixed
Posted on Feb 13, 2008
premtech
William Rayburn
  • 934 Answers
Hyper module - need to rebuild them though they are NLA and have been for some time...
Bill
Premium Technologies
[email protected]
Posted on Jun 30, 2008
My toshiba 65 rear projection is blurry and has dual image
The fluid that is used to cool the face of the 3 tubes has become clouded and discolored. This fluid is serviceable. I wouldn't try it myself if you've never done it before. A TV shop can do the job.
Oct 09, 2014 | Toshiba 65H82 65" Rear Projection...
Lens positioning, blurriness
need replace convergence ic chips to resolve this issue, parts cost about $40
Dec 19, 2010 | Toshiba 57H81 57" Rear Projection...
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
My Toshiba 57H81 has a 'jittery' picture.
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
Jumpy tv
Hyper module needs to be rebuilt..
Aug 01, 2008 | Toshiba 57H82 57" Rear Projection...
Bill
[email protected]
Feb 18, 2008 | Toshiba 57H82 57" Rear Projection...
Dec 26, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 picture bounces. Can't tell if horiz. or vertical.
Unstable picture, wavy, jittery, and loss of sync are a symptom of bad capacitors in the hyper module. The problem is worse when the set is cold, but when warm the sympton gets less or goes away. In the latter stages the problem never gets better even after the set has been on for hours. There are about 6 surface mounted caps (10mf/16) inside the shielded Hyper module. The module is vertically mounted behind the jack panel and can be unplugged from its socket after unsoldering the 4 anchor tabs on the bottom side of the PCB. This type of repair should be made by a qualified technician do to the complexity of chassis removal and expert soldering skills.
Oct 25, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81
Go to the convergence and align the red and blue + - Under Menu then Picture then convergence to get to this screen- Hope it helps
Mar 24, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
268 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
