Question about GE 30 in. Profile JP938 Electric Cooktop
GE jp938 just quite. No response to any of the
GE profile cooktop model jp938 just quite. No response to any of the controls.Voltage is present at the input. What failed?
  • chsaez May 11, 2010
    This unit has to lights that indicate if the unit is on the other indicationg if the surfice is hot. If any on those two lights were to go out the unit will not work
    President:
  • 1,891 Answers
Ck the internal wiring under the top / it may have burned a wire end . make shure you have power on both lines ( 220 v ) m m
Posted on Nov 20, 2009
Testimonial: "Answer provided a clue in finding the problem. One side of the circuit was ded. Thanks"
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
When I use the front right burner on high, it keeps clicking on and off. Both the small and large burner does the same thing.
Sorry to read about your problem, I hope this helps you out.
you have a defective sensor control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
werewr
Dec 23, 2010 | GE 30 in. Profile JP938 Electric Cooktop
What specific type of pots and pans are best to use/ avoid with the profile electric cooktop?
Hello, I hope this helps you out.
any kind of pot is ok
Dec 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Halogen burner does not work
They burn out or relay on main control board is defective....you will need a service tech
please rate/vote on this response
Dec 19, 2010 | GE 36 in. Profile JP969SHSS Electric...
Can I place a glass kettle("Whistler" brand)
yes you can no problem
Dec 18, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
GE Profile Cooktop JGP933
you hit the nail on the head remove the knobs and spray wd40 on each area where the valves been removed make sure no flame is present.
Nov 19, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
GE 30 in. Profile JP938 Electric Cooktop Logo
229 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
