I have recently bought new ink for my brother mfc 255cw. While it was running low ink, it would print out copies colored purple. even though I have already purchased and replaced all the ink cartridges, it still is coming out as purple. I just want to print out a copy of my document in black ink.
    Brigadier General:
  • 4,090 Answers
I would suspect your inkjets are blocked Black and blue =purple so the other colors are blocked up Use the nozzle cleaning function to try and remove the clog Run nozzle check after cleaning mode till all colors print correctly
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
  • 23 Answers
Check your cartridges& also check cartri... jointing place & clean it.other one go to control panal printer setting colour manage
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Brother MFC-295CN printer was stored for 2 years. Black ink won't print now no matter if brand new cartridge.
this work for me with a mfc 255cw. why it works I don't know but I will continue to use this setting. thank you
Jun 05, 2012 | Brother MFC Office Equipment & Supplies
I have recently bought a Brother MFC-255cw. I have a problem is that when i print in black, the ink smears. It is getting really annoying. Can you help me solve my problem. Thanks.
The problem is black head in your printer is dirty, follow the instructions I found here and it should work ok again.
Hope I helped and have a nice day
May 12, 2011 | Computers & Internet
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Won't print won't run clean routine
Did you try this
Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved,
Apr 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Printing when ink is low
The machine requires all color in order to print anything, even just black and white copies. You need to install a new cyan ink before it will print.
Feb 10, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Dec 15, 2007 | Brother MFC 420CN All-In-One InkJet...
235 people viewed this question
k24674
jasbo
jasbo
