Question about HP Photosmart C7180 All-In-One InkJet Printer
My HP C7100 says that there is a paper jam when theres not.
My HP C7100 says that there is a paper jam even though i spent several hours clearing it of any paper stuck in the printer.When i finished clearing it, i closed the front and back door and it still says that there is a paper jam.
  • 235 Answers
If you said that you have cleared it of any paper then its time to have your printer check by a printer technician, a small piece of paper still stuck in there will cause the printer to sya these, check it again maybe you missed a spot, if you are sure you cleared it up real good then take your printer to a repair man to avoid any furthere more damage to the printer
Posted on Nov 20, 2009
What does it means when the check paper light on a HP PSC 1210 All-In-One printer stays on even though there is plenty paper in printer?
most probably there's still a bug, insect or just a small piece of anything caught between the roller or wheel after you cleared a paper jam otherwise a spring, hook tension-er across the roller is not in-place.
Feb 23, 2012 | HP PSC 1610 All-In-One InkJet Printer
My printer says it has a paper jam, even though the paper jam has been cleared. It won't print. Any ideas?
Hi, Try pulling out the plug for 1 hour and then try again. Pulling the plug may reset the printer.
Good luck.
Jun 27, 2011 | HP DeskJet 3740 InkJet Printer
I am printing several pages and there is a jam. I
It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on HP.com. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
Paper jam display even though no paper jam anymore, unless there are tiny pieces left inside after i pulled the paper out
check near where the paper enters the roller for pick up and use a stiff brush to clear anything small in there. vacuum the area and then power up to see if this helps
Aug 08, 2009 | HP Deskjet D2360 InkJet Printer
Hp 6310 officjet all in one paper jam error
This video won't help if it's really broken, but shows you what to do for a recurring jam on the 6310.
Apr 01, 2009 | HP Officejet 6310 All-In-One InkJet...
Paper Jam fault
there are sensors that tell the machine the paper is jammed us a q-tip to clean them, remove the toner cartridge and check under that area when cleaning the sensors.
Mar 16, 2009 | Samsung SCX-4521FG All-In-One Laser...
HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Oct 20, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
246 people viewed this question
Seeker5211
Seeker5211
