Volume automatically goes to maximum on TCL TV
Volume automatically goes to maximum on TCL Plasma TV model pdp42u3hbk.
need to find out if it can be factory reset
    President:
  • 632 Answers
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Posted on Nov 20, 2009
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
SAMSUNG HP-5033 VOLUME GOES TO MAXIMUM WHEN TURNED ON AFTER BEING SHUT OFF
One possible cause.
The Function Buttons on the TV have shorted,particularly the Volume button. The part is a PCB (Printed Circuit Board) and needs to be replaced.
Apr 11, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
Need a service code for TCL TV model DP29E10C
Hi, tcl dp29e10c model
The TV's horizontal display is messed up and I need the service mode code to be able to do this
Aug 20, 2009 | Tvone TV-207 Television
Samsung 50 in Plasma volume Problem. Please help!
In the menu, there should be an option for AUTO VOLUME, see what this is set at, change it and see if it works. Also there is another option for INTERNAL MUTE, though I still haven't found out what it's for, myself. Give both a go. If neither of these work, try looking at the support pages on the Samsung website. Other than that, I can only suggest you take it back to where you purchased it, and ask for an exchange.
Nov 28, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
This sounds like there is a stuck button. With the TV off, try each of the panel buttons. You should feel the button engage. If not, that is the faulty one that should be replaced. Also, check to be sure that the plastic covering that extends to the actual switch inside the set is not broken causing a switch to be stuck on.
Keep us posted.
Dan
May 01, 2008 | Televison & Video
No sound
maybe in your cable box
Mar 30, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Jan 30, 2008 | Televison & Video
Televison & Video Logo
1,346 people viewed this question
Top Televison & Video Experts
Electro Med Services...
