Question about Brother GX-6750 Typewriter
How can I darken the letters on the display screen?
    President:
  • 2,976 Answers
The user's manual doesn't give any information about changing this. It is probably preset.
Posted on Nov 20, 2009
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
Contrast Problem
You will need to adjust the contrast and brightness down to about 50%.
Apr 20, 2008 | HP L1706 17" LCD Monitor
Dark blue screen can't see display.
With the calculator on, hold the ON button and press the - button to lighten the display. If you go too far, use ON and + to darken the screen.
Aug 28, 2011 | HP 48G Graphic Calculator
My 7570 has a blank screen when I turn it on it is lit up nnothing comes up.
There is a small wheel below the buttons on the right hand side that can be turned "up" or "down" to see the electronic letters properly. Sometimes that gets bumped accidentally and the screen appears to go blank - it's still there, just needs to have the letters darkened - they are just washed out. Turn the little wheel and it should return. If that doesn't work, quite possibly there is something else going on. If you can stitch even without seeing the screen - that most likely is the answer. Good luck! S
Apr 19, 2011 | PfaFF Creative 7570
How do I darken the display
  1. Turn calculator ON.
  2. Press [SHIFT][MODE] to access the [SETUP).
  3. Use Down arrow to display the other setUp options.
  4. In new screen select [6: <CONT>] and
  5. Press RightArrow to make screen darker.
Feb 22, 2010 | Casio FX-115ES Scientific Calculator
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Nov 14, 2009 | Texas Instruments TI-86 Calculator
Display flickers and darkens
There are two main possibilities.
1) The cable between the inverter and backlight burn on the screen is loose. You will need to open screen to reseat it.
The other is that the inverter or backlight is dying and your display will stay dark sooner or later.
If you find this helpful please rate so.
Thanks
May 06, 2009 | Computers & Internet
Random Flashes on Macbook 13" native screen
you could try reseting the pram. this is accomplished by holding down Command, Option, P, and R at startup you will want to hear the start up tones at least three times. if that doesnt work you might have an inverter issue, the inverter is located behind the screen and needs to be looked at by a pro
Jan 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I accidentally dimmed my display screen, how do I fix it?
Hold the 2nd function button down while pressing the up arrow to darken the screen, alternatively hold the down button to brighten.
Nov 11, 2008 | Texas Instruments TI-84 Plus Calculator
Display is so light that I can barely read it, I've replaced the batteries and no change
Have you attempted darkening the display on the calculator through the function keys? Push "2nd" and then push "up" a few times. After resetting the calculator, this setting will always revert to a lower, unreadable setting. I'm sure TI knows about this, but they probably arent too inclined to fix it.
Jun 04, 2007 | Texas Instruments TI-83 Plus Calculator
Brother GX-6750 Typewriter Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
