Question about Nintendo Wii Console
Console will not turn on after being properly checked in and all power sources have been checked. The unit has been idle without use for some time. Why will it not turn on??
    Sergeant:
    Champion:
  • 212 Answers
Try to change the clock battery which in small bay on bottom of unit. should be a cr2032 3 volt battery. Good Luck. Alot of laptops will not turn on when this same battery dies. Good Luck.
Posted on Nov 20, 2009
I have a stairmaster 4400 and every time I get on and try to select a workout it says config rqrd and if I push the clear button it turns off
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Feb 26, 2014 | Stairmaster 4400 PT Stair Stepper
Every time I get on it says config rqrd and it won't let me select any workout it just turns off
Corrective Action
Incripted wii remote
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
Dec 01, 2011 | Nintendo Wii Console
I just purchased a toshiba mini notebook NB 505 it has about 5 hrs. of time on it. Went to turn it on the other night and when it starts up the screen was lite up but nothing else. I can not shut down...
It happens when the NB was not properly shutdown, NB was turned off due to battery drained and left idle or worst there is a problem with the mother board. You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it back from the reseller for replacement.
Mar 23, 2011 | Computers & Internet
NOTE BOOK SCREEN DOES NOT COME ON
Screen does not come ON or not showing any display even the power LED is lit. Sometimes it is due to the laptop was not shutdown properly or the battery was drained or laptop was left idle. This is a simple solution that may fix the problem. If the power LED is lit, turn off the NB, remove all the power sources (battery and charger). Without the power sources, hold the power button for 10 secs and put the power sources back and turn ON the laptop. If this doesn't resolve the problem, it needs to be checked for possible Motherboard problem.
Hope it works!
Mar 12, 2011 | Acer Aspire One PC Notebook
Our refrigerator lights are all flashing and the ice dispenser continuously opens and closes.
I have reviewed your problem and have the fallowing for you to aces.
This sounds like to have had a power serge and a possible problem in a power board.
Please try the fallowing.
First, disconnect the unit from its power source.
Next, please check voltage at the power source and verify that it is correct.
Next, please check the ice maker and remove any ice or particles that may be restricting normal operation.
Note... I assume that the unit is cooling and freezing properly, as you have no listed complaints.
Note..... I am asking you to disconnect the unit from its power source and not turn unit off and control panel.
Also, You will want the unit to sit for at least 10 minutes with power disconnected, in order for the unit to reset.
Finally, please re-connect the power source and in available, please push reset on panel.
I the unit work properly afterword's, please have unit serviced asap.
Please let me know if you need anything.
Please rate......
Oct 30, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
How to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
Mar 27, 2009 | Pioneer DEH-P2900MP CD Receiver...
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
Red light on startup
This happened to me 2 or 3 times.I checked the power supply and found that it was loose(the one in the back of the actual 360 console)when I pushed it in properly,is worked fine,i have not got this problem at all since then.So just make sure the power supply is properly connected.
Jan 17, 2008 | Microsoft Xbox 360 Console
Nintendo Wii Console Logo
189 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
