Question about Kodak EasyShare Z1012 IS Digital Camera
My flash isn't working, it pops up but no flash goes off
    Brigadier General:
  • 4,090 Answers
Common fault!
To Take to camera shop and have it repaired It costs about $105 You would be better off buying a new camera than fiddling around with this
if its under warranty get on to Kodak and dont back down on this.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
    President:
  • 2,976 Answers
Make sure that you have a lightning bolt visible on the screen. If it has a slash through it, it is turned off. If it has an eye shape aroung it, you will get extra bursts before the shutter opens. This is used when taking pictures where there are people or animals present. The flashing will close the pupils of their eyes and prevent a lot of "red eye".
Flash does not fire
Does flash pop up? Does the little electronic flash symbol appear in the LCD when it charges? Really not enough info in your post.
A few thoughts:
If the flash will not pop up check the external flash detection pin in the hot shoe (located on one side under the spring, which can be popped off with a knife blade or similar). If this is stuck down the flash will not pop up because the camera thinks there is an external flash in the hot shoe.
If the flash pops up and you get an 05 error or it makes a clicking noise and you get an 05 error this usually means sticky liquid spillage around the flash. It needs to be disassembled and cleaned and the pivots lubed. Squirting WD40 on the flash WILL NOT SOLVE THIS PROBLEM. NEVER SQUIRT WD40 IN ANY CAMERA!!!!!
It the flash pops up, and the little electronic flash symbol comes on, but goes out when you push the release button it usually means the flash board is bad.
If the camera has been impacted, then either the flash tube is cracked/broken or one of the wires that goes to it or the trigger coil may be broken inside
Mar 11, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Nikon D5000 flash issue
Sounds like the flash tube is bad. Another possibility would be a bad flash capacitor or circuit. Has the camera been impacted - especially around the flash?
Another possibility is that the light tube that goes from the frame around the tube to the sensor further back in the flash base has come loose or impact has broken the frame.
Pop up the flash. Underneath there are two screws; remove the screws, push the flash back down and using a slim piece of metal pop off the flash cover. You can then see the tube and the light pipe (looks like a thick black wire) and the sensor located at the back on the right.
Be very careful. There can be over 300 volts across the flash tube - do not touch!!!
Apr 30, 2013 | Nikon D5000 Digital Camera
My Chevy 2,000 Mailbu will not start. Sometimes when I try to start it the trunk will pop open. Can you please help?!
Its time to replace the battery. This is common in Chevy cars, if the battery goes bad it doesn't hold a charge anymore. Whats happening in your case is the low voltage isn't keeping the trunk relay closed. When you turn the key all the juice goes to the stater and lets the truck pop open. Just to prove my point, give it a jump start and it will fire right up and the trunk will stay closed.
Dec 13, 2011 | 2000 Chevrolet Malibu
The usb drive isn't working
sometimes if you just unplug the usb without useing the computer to disconnect from it. it can lock up or erase it, most systems have a green indicater in the lower left toolbar to click on before unplugging it. when you first plug it in a window should pop up asking if it is ok to fix the flash drive hit yes, or ok
Nov 17, 2011 | Toshiba Satellite L555-S7002 (4400 mAh)
Radio on 2008 dodge nitro stops working it goes out for a while then comes back on. no sound even when turning the volume up and down. it makes a loud popping noise and goes out.
Im having the same problem! No pop, just a hum, and my volume dial won't adjust. Like the actual dial isn't working. I can't use radio, cd, or aux. Silence SUCKS.
May 31, 2011 | 2008 Dodge Nitro
I have a sb-600 flash. It works fine but it has
Try doing a reset - press the "Mode" and "On/off" buttons together for a few seconds and you go back to factory settings. Sounds like you got into some funky mode, assuming everything else is working ok.
Mar 09, 2010 | Nikon Speedlight SB-600 TTL Flash
Flash will not pop up
depending on the type of camera just hold the flash button and if that dosent work then gently put a flat screwdriver and lift up.
Mar 30, 2009 | Canon Rebel XT / EOS 350D Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Kodak EasyShare Z1012 IS Digital Camera Logo
119 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
