Question about Cameras
My KDS-R60XBR1 turn up volume to maximum loud and stays loud
My KDS-R60XBR1 turn up volume to maximum loud itself and remote control does not work ( remote is good - I have extra one to test it.)
Problem must be in remote digital receiver board
most likely but I am not sure.
Tried to reset TV - does not help.
I went manually on TV to menu and put speakers on mute.
However I cannot use remote anymore. Receiver bad.
IS it something easy dead or do I have to replace whole board ?
    Sergeant:
  • 295 Answers
Question:
Take the batteries out of both the remotes and then try to turn the TV on with it's On/off switch built into the TV.
If it turns on and the volume stays the same, then it must be an issue with one of the remotes.
If the tv turns on and the volume ramps up to max. Please check if volume knobs/buttons on the tv itself to see if they are sticking.
If they aren't, there is something wrong with one of the boards in the tv of course. This sure should be something a Sony Service Shop can fix. I don't think it will be expensive. Maybe a $100 to $200 repair if they do the work.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Have had to replace lamp twice in the last two years on my Sony KDS-R60XBR1 HDTV. Yesterday I ended up with the four blinking red lights showing on the Power/Standby indicator nothing by the lamp...
hi,
fist of all try to reset ur tv. to reset do the following.
Turn on the TV. While holding down the up arrow button on the remote control, press the POWER (on off switch) button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
Dec 31, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
How to i reset the lamp counter on my Sony KDSR60XBR1
I understand that you replaced the new Lamp and but the lamp counter is same.
Turn On the TV. While holding the UP button on the remote control, press the POWER button on the TV. ( The Tv will turn OFF itself OFF, then back ON again). Then, release the UP button.
If its not reset, you need to call sony phone support. Chat or email support may not be able to help you
Sep 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Cameras Logo
108 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
