Question about Dell 924 All-in-One InkJet Printer
My photo 924 printer will not print at all the paper comes out blank? What can I do?
    Brigadier General:
  • 10,406 Answers
Run the software that came with the printer to display the ink-levels remaining in each of the ink-cartridges. If empty, then either replace the cartridges, or get the cartridge professionally-refilled.
Run the software to do a "head-cleaning" cycle.
When you remove the cartridge, touch the end that the ink comes out to a damp paper-towel -- does it "bleed" any ink at all? If not, it's empty.
Posted on Nov 20, 2009
  • 235 Answers
Check the printer if it indicates that you have run out of ink? then an ink replacement is necessary, but if not, and printer is not giving any indication of ink replacement or if your ink cartridge still has ink try cleaning the printer head using the printer software installed in your computer try this 4 to 5 times if nothing happened then a hardware check up is needed to see what is the cause of the problem
Dell 924 AIO printer prints blank page
The print head needs to be cleaned. If this does not work, try a new print cartridge.
Apr 18, 2015 | Dell 924 Photo All-In-One Printer
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printer working but paper comes out blank
  • go to the printer properties by right clicking the printer icon on Printer & Faxes.
  • Go to Advanced Options and select the option that reads Print Directly to the Printer.
Sep 26, 2010 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
My Dell 924 printer is printing blank pages
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | Dell 924 All-in-One InkJet Printer
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Sticky photo printing and poor quality
GO IN TO PRINTING PREFERENCES on computer AND CHANGE SETTINGS TO MATCH THE KIND OF PAPER YOU ARE USING OR CHANGE PRINTING PREFERENCES TO PHOTO WHEN PRINTING PHOTOS
Sep 10, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
76 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
