Tub is overfilling as well as leaking from the bottom when it is on the spin cycle top load Maytoag Ensignia
    President:
  • 1,891 Answers
The water overfill problem is the pressure sw . the water leak could be the over fill problem caueing the leak . must deal with first problem . the address second . m m
Posted on Nov 20, 2009
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
WATER LEAKING FROM TOP WHEN START SPINNING,MY WASHER IS MAV 7600AWW,I CHANGED THE SEAL AND STIL LEAKING
Does this happen on any water level setting, or just on full load? If the machine is overfilling, the centrifugal force at the start of the spin cycle will throw the water up the sides high enough to overflow the top of the tub.
If the machine is overfilling just a little as I suggest, then the water level switch may be out of calibration or the water level hose may be partially clogged at the tub end. A quick fix in the latter case would be to disconnect the hose from the level switch and blow compressed air through it - it's a lot easier to get into the control panel than the side of the tub. A leaky hose would have a similar effect.
Feb 04, 2011 | Maytag MAV7600 Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Jun 10, 2009 | Washing Machines
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
