Question about Brother MFC 8500 All-In-One Laser Printer
Drum has 13% life left; white paper w streak in middle when you copy
Pressed a button the other day and got these menus that said machine has 13% drum life. This explains why the white streak down the middle
when you copy. Also, it has starting to not want to send your fax
without sending several times over and over again. thanks
    Master:
  • 788 Answers
Try taking out the cartidge and given it a light shake. If the white streak moves or changes then you are out of toner.
As for sending faxes, do you get an error message an any kind? Does it try to dial?
Posted on Jan 11, 2008
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
Prints are having black lines and smudges along the sides of the paper. What do i need to clean?
Unfortunately when it comes to toners and drums there isn't much that can be fixed with cleaning. It sounds like either your toner cartridge is worn or defective and spilling toner, or your drum could need replacing and therefore is acting up. To check if it's the drum, pull out the drum unit and look at the drum roller (but don't touch it!) you should see streaks or color changes on the roller in places matching where the smudges on the paper are if the drum needs to be replaced.
My bet is on the drum. Drum units are fairly easy to get a hold of, since it is a "replaceable" part of the printer. And if you can install the toner you should do fine with the drum unit as well.
Hope this helps, good luck!
Aug 18, 2010 | Canon imageRUNNER 1023iF Black and White...
When i copy o print a document, it comes out with tonner and black dust stains, how can i clean it? Ricoh Aficio MP 1600
a) If possible remove the drum unit and see if there is a paper stuck in the drum unit.
To remove the drum unit first open the front and right door. Then remove the toner holder(green lock).
Then pull the drum unit out from the front of the machine(press the lock).
b) How many prints(copies) has the drum made ?
The life is 60000.If it has crossed its life replace it along with the developer.
Feb 16, 2010 | Ricoh Aficio MP 1600 Black and White...
Black Streaks
pull drum unit out and clean corona wire by sliding blue plastic tab from side to side, making sure you put the tab back on the side that it was. if that doesn't take care of problem, then i would say you need a new drum unit.
razors
Jan 27, 2009 | Brother MFC-8440 All-In-One Laser Printer
White bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
LONG WHITE VERTICAL LINES
It sounds like the drum may need to be replaced. The streaks may be caused by sections of the drum no longer being able to hold a charge and therefore, toner will not properly stick to the paper in those sections and you'll be left with long white streaks on the paper. This is a usual symptom of a bad drum.
Jan 13, 2008 | Sharp AL-1000 Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
232 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
