Question about Kitchen Appliances - Others
Can not get my oil to heat more than 250 degrees on my turkey fryer what am i doing wrong
    Brigadier General:
  • 4,090 Answers
Make sure the knob is actually anchored to the shaft. There is a screw that binds the knob to the flat spot on the temp control. This should be tight so the shaft turns not just the knob. If it is firm then your temp control is faulty and needs to be replaced.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
My flame keeps on going out on my turkey fryer it has a heat sensor on it how do i position the sensor so the flame doesnt go out
The heat sensor for your turkey fryer is preset to 375 degrees F. Once the oil reaches that temperature, the sensor turns the flame OFF, so that the oil will not boil over and ignite. Once the oil cools to 325 degrees F, the burner can be relighted . Use extreme caution when relighting the burner. Altering or repositioning the heat sensor would make the fryer unsafe to operate.
I'm sorry. I which I had better news for you. Always, err on the side of caution & safety when dealing with open gas flames.
Jul 06, 2011 | Brinkmann 815-3530-2 Turkey Fryer
Flame goes off when temp. reaches 250 degrees, use to stay on 350 degrees without problems an them started acting up and won't reach that temp any more, disconnect the pilot automaticly
Hi limit device trips prematurely (should only trip when oil temp reaches 450F). Check if the hi limit sensing bulb (located inside the fryer tank, between fire tubes) is not touching the fire tube because if it does, it will sense the heat from burner flame which is much higher than oil temp.
Feb 21, 2011 | Pitco Frialator 45C Deep Fryer
How to do cheat
Not sure exactly what you're asking due to a type-O. But, I going to assume your meant "How to do heat".
Admittedly, this is not the easiest electric turkey fryer to start out with, but it does do the job pretty well.
To start heating the oil and setting the cooking temperature, you must do the following.
Press "ON"; then "Temp Heat"; then press the up arrow until it reaches 400 degrees (for frying a turkey). You may have to push a button more than once, because I think the first push is to light up the screen.
Hope this helps you solve your problem and gets you going.
Feb 18, 2011 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
I deep fried my turkey for 1hr but the legs were still not done and the skin was not crispy. The rest of the turkey was cooked and the bones were brittle enough to snap the legs off easily. What went...
make sure that u have the right amount of oil of ure choice and 5 min per lb probe with fork if it spins freely turkey is done ( FYI after you checked ure turkey take out of oil and dust turkey with some seasoned flour drop back in oil for 2 min for great outside crust as said in louisiana "that what u call a deep fryed JO---JO
Dec 29, 2010 | Brinkmann 815-3786-0 Turkey Fryer
Unit wont go over 250 degrees
Was this with or without the turkey in it??
If with, then was the turkey cold or possibly still frozen inside??
If without then either the element is going bad or maybe you have it on a long extension cord and it cannot draw enough power...
heatman101
Nov 26, 2010 | Masterbuilt 20010306 Deep Fryer
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
How hot does the oil has to be to fry 19 lb turkey
The oil should be hot enough so that when a drop of water is droped into it the oil will sputter, but not not hot enough to cause any smoking vapors!
Nov 27, 2008 | Masterbuilt 20010306 Deep Fryer
Cecilware Fryer electric
you have a bad high limit the range on this should be around 600 degrees.
Apr 16, 2008 | Cecilware EL-250 Deep Fryer
Kitchen Appliances - Others Logo
100 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
