Question about Delta & Single Handle Shower Faucet
Leaking shower faucet
This is the only place I have been able to find ANY reference to the ball, springs and rubber caps that sound like the way my shower faucet is built. The rubber cap(s) was in pieces when I took the thing apart so I have no idea how they were SUPPOSED to go together with the spring(s) and cannot find any diagrams to address this. How many springs, how many rubber caps should I have??
I have a single handle delta shower faucet and water continuously drips out of shower head
Posted on Dec 08, 2009
  • 8,197 Answers
You should have 2 springs and 2 rubber caps. How it goes together is if you pull the ball out you will see 2 recessed holes. You will have one spring in the recessed hole then a rubber cap over the spring flat surface out. You need to do this on both holes behind the ball. Reinstall the ball and put handle back together and you are done. you should not have a leak after.
Posted on Nov 20, 2009
    Sergeant:
  • 275 Answers
I do believe that Delta guarantees their faucets for life. Go online to get the 800 number and call them, have the model number ready. They actually sent my girlfriend a replacement for her $300 kitchen faucet and also the guts to 2 bathroom faucets. They come with diagrams also. Of course I had to install them, but they stand behind their stuff.
Can't regulate a delta shower.
If you have the type that you turn the handle like a clock, you have to find that perfect spot. It can be 3/4 of the way around. If you have the ball type, single lever, the rubber seats and springs under the ball should be replaced. Cost...less than $10 for the kit to do yourself.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
Two faucet shower control hot water faucet leaks- I took of the cap, handle, and unscrewed the long screw and there was a long white place stem. Is this where the seal goes.
You will need to remove the cartridge that the screw was attached to and underneath there is a rubber cup washer with a small cone shaped spring. You need to replace the rubber washer which is called a seat and the spring ,then put cartridge and handle back on and you should be good to go. Thank you.
Feb 17, 2011 | Delta Home
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Leaks
    replace rubber seat cups and springs. replace stem and ball with brass parts if available.they last longer than the nylon ones. lubricate moving parts with valve stem grease. do not over tighten when re-assembling
    Sep 16, 2010 | Delta Faucet Home
    Leaky shower head
    If you replaced the seats and springs and the problem continued you may need to get a whole rebuild kit including the ball and replace that one as well
    Jun 27, 2010 | Delta & Single Handle Shower Faucet
    Delta single lever faucet leakingafter bing shut off.
    Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
    Jun 26, 2010 | Delta & Single Handle Shower Faucet
    Springs have been replaced and it continues to leark
    Did you rplace the rubber caps that go on the srings? Also it is a good idea to replace the ball also.
    Nov 11, 2009 | Delta & Single Handle Shower Faucet
    Delta & Single Handle Shower Faucet  Logo
    925 people viewed this question
    Top Delta Home Experts
    Mike
    john h
    Tim Whalen
    Are you a Delta Home Expert? Answer questions, earn points and help others
