Question about Toshiba 50HP95 50 in. Plasma Television
Black box There is a black box in the bottom right corner. I shut off closed caption and restet the tv to manifacure defaults but the box still will not go away
    Problem Solver:
  • 61 Answers
Black box by itself coud be a software issue call toshiba tec support or could be in some stuck in a service mode for the factory regardless you will need to call tech support
Posted on Mar 31, 2008
  • Mark Hammonds May 15, 2008
    You have to go in to the service menu and turn of the factory test mode
Black box in the lower right corner of my Vizio flatscreen will not go away.
Hi Marvink,
black blank box is connected to CC or closed caption. from the tv controls, push the CC button and while the box is reading closed caption, push button again (maybe twice) and when it says OFF simply set the controls down, Good Luck:}
Nov 17, 2012 | Televison & Video
We get a black square on Fox and one children's cartoon network only. I have close captioning set off on my Uverse box menu. Is their anything else I need to do on the Olevia setup menu to eliminate the...
This is most commonly caused by the use of a Closed Caption text box. This type of Closed Caption is not always supported by the broadcaster, and results in the appearance of a black rectangle with scrambled or no text.
This can be quickly resolved by adjusting the Closed Caption type to "CC1" or by disabling the Closed Caption feature on your television.
get in the menu and change the close caption with the Olevia remote control
This should fix you right up
Dec 03, 2010 | Televison & Video
Black square on screen of 19 inch TV
Check your closed-caption settings and be sure they are turned off. If captioning is set for text mode you can have this trouble. The TV blanks out a part of the screen for the text it never gets to display. Once captioning is shut off (or set for normal caption mode if you want to use it) the black box will be gone.
Feb 04, 2009 | Konka K1938U 19" TV
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Tv Has Big Black Box
shut off close caption. use the CC button onthe remote or go in to the menu and change close caption to CC1. this box is the close caption in TEXT(1,2) which will put on a black box whenever there is caption present.
Feb 22, 2008 | Apex Digital PF2720 27" TV
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Blach block out
if your big black square starts about the middle of the tv & goes down close to the bottom, you have closed caption text turned on. normal closed caption is small, but test caption, is just a big black box with no writing in it. go into your menu & shut it off, it could even be a button on your remote called, "caption", or "cc". good luck.
Dec 27, 2006 | Samsung TXJ2067 20" TV
Toshiba 50HP95 50 in. Plasma Television Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
