Question about True Refrigerators
Clicking several times then comes on for about 2/3 min then blows breaker
    President:
  • 1,891 Answers
You may have a bad p c board / this board controls the start up and defrost cycles . also blowing of breaker could be a short . may be a bad comp . how old / is cond clean / is to on a ext cord / or a ground fault plug . hop this will help m m
Posted on Nov 20, 2009
Outside main 100 amp breaker is tripping but none of the inside breakers, supposedly when dryer and tv on together but not all the time
Am I to assume your dryer is electrical? If so, I'll guarentee it will draw MORE than 14 Amps if heating. Sorry, can't analyze your problem from here.
May 01, 2014 | Cutler Hammer 100 Amp Main Breaker...
Sanyo repairs built-in transformer
Most refrigerators draw up to 12 amps on a lock-rotor.. meaning it reached temperature, and turned "off" there needs to be 5 or 10 mins, before the compressor can restart due to hi-pressure inside the condenser . usually you will hear the fan(s) come on, it makes a "click" sound trying to start- that's called a Lock rotor. when People seem to have problems asking about how many Amps. it's because they trip their house breaker. I will assume and respond under that pretext - 1) 15 amps minimum on a dedicated line, means only that item. 2) house breakers weaken over time and will trip - here's how you can tell the difference If your breaker trips the instant you plug in your refrigerator.. 90% probable problem with refrigerator, a short somewhere is causing the breaker to open the circuit . if you plug in, and Refrigs runs for any length of time, and then the breaker trips. The refrigerator is combing it's consumption of Amps, contributing them with something else so together they exceed the rated voltage or you need a new breaker.
Nov 29, 2013 | Refrigerators
Goodman a/c @ heating unit. Model #gmh80703anca when I turn the unit on it keeps blowing the fuse on the circuit panel. What could be causing this?
Several questions:
1. What fuse? 110V at the furnace? Breaker at the house? Fuse on the controller board?
2. Does the ignitor work? Do you get gas ignition?
3. Does the exhaust fan come on?
4. Does the main blower come on?
Apr 15, 2013 | Heating & Cooling
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
Mar 27, 2012 | Microwave Ovens
My neptune electric dryer keep blowing the breaker after ten min
If the dryer is running then blows the breaker , then it is not in the electric circuit, There is a fault in the dryer itself. If it blows the circuit at the same place in the cycle each time then there could be some fault in the heating coil or in the timer circuitry.
Dec 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motor is from a table saw; it rans badly only for a short time and it blows the breaker. Thanks for info Chris Schwarzmaier Additional info: single phase 220, 2 hp, no interial centrifugal switch, start...
Check the brushes to see if they are worn. Also, check the commutator (where the brushes run) Double check the capacitors to make sure that they are the right value. Most motors that size can be wired several different ways -- make sure it's wired right for your hookup.
Dec 03, 2009 | Cars & Trucks
My dryer ran for about a min. It then quit and
Did the circuit breaker trip or fuse blow? Check to see if the dryer is getting power.
Sep 12, 2009 | Dryers
Outside unit trips the circuit breaker
seems that if it runs for 5 minutes there shouldnt be any shorted wires I would say your breaker needs replaced
Aug 04, 2009 | Weather King 10AJA6001AH Air Conditioner
Rheem Classic X Humming
does the indoor fan come on if fan comes on then the problem is out side if the fan is not coming on and the breaker blows this will turn off the out door unit also due to the 24v transformer is located in the indoor unit your system has two breakers one for out door and one for indoor units as far as your contactor goes with power off look at the contacts if pitted bad replace it most need replaced after 5yrs also check for voltage drop on the load side look at the capacitor to make sure it is not swelled up on top if so then bad unplug the fan motor and bump the contactor with an insulated object to make sure the compressor is running if not with power off remove the cap on the side of the compressor and look to see if wires are connected good they some times get lose and ends burn off also on the contactor they some times buzz when bad hope this helps with your problem
May 15, 2009 | Heating & Cooling
Friedrich QuietMaster SS12H10
It is probably either the Compressor and or the capacitor that has failed. The compressor will hum and pull a lot of amps when it has seized up. Sounds like it is time for a new unit.
Jun 30, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Refrigerators Logo
362 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
