Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
WATER FLOWS TO ICEMAKER BUT NOT TO WATER DISPENSER,TEMPERATURE ON THE FRIDGE SIDE WILL NOT STAY AT 37
    President:
  • 1,891 Answers
If the tempt gets to low it will freeze the water blater and you know what ., the control will have to be repl to stablize tempt . m m
Posted on Nov 20, 2009
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Freezer and fridge tempeture increasing.
The black " tank " is the compressor . Will the fan by the compressor run ? If not , that is the problem ( fan motor ) . Are the coils clean of dust , lint , pet hair , etc ? The brand and model number would have helped . Since the compressor is hot , means it should be good . The fan motor must be working , to help keep the compressor cool . Also , the back cardboard or metal panel must be in place when finished , or the fan will draw outside air instead of front air over the coils and compressor .
Aug 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Refrigerators
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
149 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
