Question about Texas Instruments TI-89 Calculator
TI-89 i am very frustrated... i used graph link to transfer notes to my calcaultor but it said send failed. why? its really urgent i need notes to be transferred to my calculator. thanks!
  • Texas Instru... Master
  • 8,073 Answers
My first answer is obvious: you can type them in the Editor.
Why did the transfer fail?
  1. File type incompatible with the OS.
  2. Not enough memory left to hold the file.
  3. Transmission error due weak batteries.
  4. Transmission error because the graph link end of the cable that goes into the IO port of the calculator is not fully inserted.
  5. Baud rate of your computer Serial port may be too high. Set it at 9600 bauds or less.
These are all the reasons I can think of. You may try to upadte the TI Connectivity software to the latest 1.6 version, if is not already 1.6
Hope it helps.
Thank you for using FixYa.
Posted on Nov 20, 2009
I just got my sister's TI-89 calculator and I don't know how to use it. I'm trying to find out how to graph a non-linear inequality. Any ideas?
You can download the manual from the manufacturer's web site at
http://education.ti.com/calculators/downloads/US/Guidebooks/Detail?id=6128
There's also an aftermarket book:
http://www.barnesandnoble.com/w/ti-89-graphing-calculator-for-dummies-c-c-edwards/1013991784?ean=9780764589126&itm=1&usri=ti%2b89%2bdummies
If you're lucky, a local library will have it.
Aug 23, 2011 | Texas Instruments TI-89 Calculator
Urgenttttt --- when i used notefolio on my computer to transfer notes to my calculator TI-89... i could not find transferred notes on my calculator!! where can find it?? or do i have to download...
You need to install notefolio to your TI-89.
You can download the program from:
http://education.ti.com/educationportal/sites/US/productDetail/us_notefolio_89.html
After you download the program file, you can use TI-Connect to transfer the program file to your calculator (after you connect the calculator to the computer with the USB cable). To transfer the files, simply drag and drop the program file onto the TI-Connect icon on your computer.
To learn more about the Notefolio app, here is the guidebook:
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&appId=6204&tabId=2
Nov 25, 2009 | Texas Instruments TI-89 Calculator
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Cannot connect ti 89 to computer. I have installed the correct software from the ti 89 website for my computer and my calculator when I satart ti 89 connect it tells me there is an error.
Check to make sure TI-Connect is looking on the right port, whether USB or serial. If you have a serial cable, you might consider using Ti's Graph-Link software to connect. I have had trouble getting it to work right with TI-Connect. You can find Graph-Link on TI's Education site under Downloads > Connectivity Software. I personally prefer the free program TiLP, which runs on Windows, Mac, and Linux and supports whatever cable you want. Hope this helps!
Sep 29, 2009 | Texas Instruments TI-89 Calculator
I want to get preos browser
Try this: PreOS on ticalc.org
You can transfer it with TiLP or one of TI's programs (TI Connect or Graph Link, google them if you need). This should reinstall PreOS or put it back on if it got deleted.
Feb 05, 2009 | Texas Instruments TI-89 Calculator
Ti-89 help
You create a program by using the program editor. Press the "APPS" key and select "Program Editor".
What type of data graph do you want? The TI-89 can plot Scatter, XYline, Box, and Histgram graphs. Use the "Plot Setup" screen to select the desired plot type.
Apr 17, 2008 | Texas Instruments TI-89 Calculator
I accidentally resetted my ti-89 titanium
Use the TIConnect software to connect the calculator to the computer.Then in the TIconnect main window you can drag and drop the applications you downloaded from education.ti.com. They will be transferred to the calculator.
I cannot understand why you cannot graph normally since the graphing is not an application, it is part of the OS.
While you are connected to the Internet and to the calculator, you may want to reinstall the OS directly from education.ti.com to your calculator
Hope it helps.
Feb 22, 2008 | Texas Instruments TI-89 Calculator
Ti-89 wont turn off
I'm having the same problem:(
I need to solve this urgently, i can't stand always being removing the batteries... please help me!!!
Oct 16, 2007 | Texas Instruments TI-89 Calculator
Uploading From Computer
Are you using TI Connect or TI GRAPH LINK ?
Aug 03, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-89 Calculator Logo
498 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
