Question about Canon imageRUNNER 1023N Black and White Copier
How to change the drum - Canon imageRUNNER 1023N Black and White Copier
  • 78 Answers
Open the left hand door grab hold of the 2 marked levers pull out old drum then insert new 1 goodluck
Posted on Nov 30, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
It say drum end soon and i dont know what this means as i put a new ink cartridge in it and it still keeps coming up the same.
Your unit obviously has a separate drum and toner.
Changing the toner, doesn't change the drum.
You will need to change the drum soon.
Jun 24, 2011 | Brother Office Equipment & Supplies
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Needed to change drum...so did that. Just changed
I am not sure what kind of printer this is, but see if there is a reset menu for the drum. also the manufacturer website might have some info on how to reset the drum counter.
Jul 31, 2009 | Dell 1720dn Laser Printer
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Brother drum replacement
you could damage the gears if the drum jams up but that unlikely
Jan 16, 2009 | Brother DR-400 Replacement Drum - 20000...
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Change drum soon will not clear after new drum inserted
This machine is reset with a plastic sheet that come in the new drum unit. When the drum is inserted for the first time, the sheet slides out and trip the exit sensor in a certain way. Then the counter is cleared. If you still have this clear plastic sheet, then you can reinsert it into the top of the drum unit and try it again.
Jun 30, 2008 | Brother MFC 4800 All-In-One Laser Printer
Changing Drum
The drum is where the image is applied before being transfer to the paper. If the drum is wearing down the image will become poor. Changing the drum unit will make the image like new. So, yes you can run the drum catridge until you get a poor print out.
Apr 24, 2008 | Brother MFC 4800 All-In-One Laser Printer
Brother PPF-2800 Fax Drum "change drum soon"
this it brother web side go there and will tell you how to do http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007573&Sympt=Why+does+the+display+still+show+CHANGE+DRUM+SOON+after+I+replaced++thedrum%3f&Model=61&ProductGroup=2&Keyword=change%20drum%20soon&ProductID=PPF2800
Apr 11, 2008 | Office Equipment & Supplies
Canon imageRUNNER 1023N Black and White Copier Logo
54 people viewed this question
old marine
old marine
