Question about Ovens
I need a manual for omega oven,model not known.
I recently bought a villa ,the omega stove in situ has no oven manual,I seem to have only the top OR bottom element on at one time resulting in burning before the goods are cooked. can any one help out with a manual?
  • 10,865 Answers
Hello. If your stove is manufactured by Omega Appliances, it appears that they no longer produce it. That said I can speak to your heating element issue. When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you would like to contact the Omega Appliance company directly, you can reach them as follows: http://omegaappliances.com/contactus.php
Posted on Nov 20, 2009
I have a stoves double oven the fan oven heats up but not hot enough could it be the stat and if so how do i replace it.
It could be the stat. First check that the sender unit located at the top rear of the oven above the fan cover is bright and clean and not covered with dirt and grease. Use a paint on oven cleaner to clean it in situ as it is quite easily damaged. Lakeland do one. If that doesn't work, then the whole oven unit will have to come out of the kitchen carcass and the the top and rear oven covers removed for access. Try espares for the part. If you want to check the oven temperature before you start, Lakeland do an oven temperature thermometer for about £5 which I have found is accurate.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
Fan oven does not heat up to correct temperature, but the light goes out so it thinks it does. Need new thermostat for the oven but where do I get one from. The oven is a 720EF Heritage
You can try espares. If it is not listed, there is normally a help section where you can send in a request. You will need the model number as well to ensure you obtain the right version. (It could be something like 059040415).
If you want to check what the oven is doing before buying the new parts, Lakeland do a reasonably priced oven thermometer, I think about 4 or 5 pounds to see what temperatures it is reaching. Also check the thermostat sensor. It is the long thin cylinder in the top right hand corner of the oven. It should be clean as a whistle and not covered in grease gunge etc. If it is, this could cause incorrect readings. Don't attempt to clean it manually as it is quite fragile, especially the connecting wire. Leave the sensor in situ and use a paste on oven cleaner which really works ( from Lakeland) and follow the instructions. it should come up bright and shiny. Best of luck.
Dec 10, 2010 | Stoves 720EF Electric Double Oven
I recently bought a home with a Kenmore Self Cleaning Ultra Bake Oven but no manual to be found. Serial # 9755994 Model 880 655 124PO. I would appreciate any information regarding this stove and how to...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Bought house,but didn't come with instructions for the stove.
absolutely but you will need to tell us which model and serial number you have
most models it can be found ion the drawer compartment
it might be on the back of the drawer front
Oct 28, 2009 | Ovens
Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Jul 10, 2009 | Ovens
I need a bellissimo oven manual
I to have brought a house with this oven and I am sure i am not using it properly, how did you go with instructions. Roz
Mar 28, 2009 | Ovens
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
715 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
