Getting error in the middle of the browsing"server busy.This action cannot be completed because the other program is busy. Choose siwtch to to activate the busy program and correct the problem.
I'm trying to scan in pictures. The program gives the above error message and I click switch to which opens the program menuI'm trying to scan in pictures. The program gives the above error message and I click switch to which opens the program menu
You can't post conmments that contain an email address.
Might as well try to power cycle the device meaning disconnect it from the computer , turn off the scanner , unplugged the adapter from the power source and then push on the power button for 5sec so that excess power will be drain and then restart the computer also as soon as your computer boots up connect the scanner .
Insert the installation CD in your computer's disk drive and
allow the installation to automatically begin. If the install doesn't
begin automatically, click on the "Start" button at the bottom
left-hand corner of your PC and choose "Control Panel." Next choose
"Add/Remove Programs." Next you will see the option to install from a
CD or floppy.
Step 2
Choose the "CD or Floppy" option. Windows
will locate the previously inserted CD and begin the installation. You
will be asked to enter your end user license agreement. Enter your
license number that is located on the box of the software you
purchased. Click "Next."
Step 3
Choose
the location you want to install the program. For example, the name of
your local disk and the "Programs" folder will be displayed. If you do
not want to install in this area, click "Browse" and go to the location
on your PC you want to install the program. Once you have chosen the
location, choose "Next."
Step 4
Click
"Install" on the "Begin Installation" page and the installation process
will begin. This process might take a few minutes to complete. Once the
installation has completed, you will receive a message the installation
has completed successfully. Click "OK," "Next," then "Finish."
Step 5
Verify
the program has been installed successfully. Click on the "Start"
button, then "Control Panel." The programs that are installed on your
computer will be listed. Verify the PowerPoint 2003 program is listed.
Are you using the web version of Yahoo messenger? If so, then most likely the server error is from not being able to complete the requested action (busy server on their end) Try again later and see if it works. Hope that helps
already did.. but no use. still getting the same.
