Question about D-Link AirPlus DI-524 Wireless Router
Cannot connect wirelessly, but can through my network cable using a di - 524
  • 2,260 Answers
If you connect the ethernet cable to the computer it works .
You will need to check the wireless settings of the router.
Also check the the wireless connection of your laptop.
To check the wireless settings of the router , you will need to open the router set up.
Click Here to know how to open the router set up.
Posted on Nov 20, 2009
How can I connect the ps3 to a wireless router di-524?
First, you need to configure the wireless adapter inside the D-Link router:
* set an SSID -- the "name" of your network
* set an encryption-level -- use 'WPA' or 'WPA2'
* set a password for your network.
Then, enter the SSID and the password on the PS3, to connect to your wireless network.
May 14, 2011 | D-Link AirPlus DI-524 Wireless Router
I want to disable wirless broadcasting in D-Link DI-524 how i can do it ?
I don't think you can disable the wireless but you can prevent people accessing your wireless network.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Alternately you can connect your computer to your DSL or cable modem without using the D-Link.
Dec 20, 2010 | D-Link AirPlus DI-524 Wireless Router
Where to find on the DI-524 wireless router the WEP key with password. Can't use Wi-Fi on the Apple IPad. Thank you
Login in using your browser using a LAN cable and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
May 05, 2010 | D-Link AirPlus DI-524 Wireless Router
The D-Link 524 is not transmitting wirelessly or via cable
This might be a bit dumb solution but try pull out the power adapter and plug it back in again. Have worked for me 3 times when I've had similar problems.
Mar 01, 2010 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
New laptop can not connect to Di-524 router
connect the router to pc via a ethernet cable, then there should be a reset pin hole on the back, press this, the router will restart and clear the password, restart pc next, then type in the routers address again and you should connect.
You can then remove the cable and connect using the wireless connection
Sep 04, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
118 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
