A disk error occured, Press Ctrl+Alt+Del to Start. ( it appears when i start my pc after performing a check disk. Anyone can help me resolve the problem?
  • oepandaan Nov 21, 2009
    Yes. That's the last thing I did with my computer. However, that message kept popping up all over again whenever I press ctrl-alt-del.
    Would a hard drive reformat be the final solution?
    I entered chkdsk /f /r on the Run dialog. When it told me to restart my computer, I did.
    Just before the black screen appeared, I saw my desktop for the last time, with some shortcuts missing and the background image all blue.
    Opening Task Manager showed some program running on the background: "Personalized Settings", which failed to respond. I didn't try to end it, although I restarted once more and the black screen appeared, which contains the aforementioned prompt.
    Brigadier General:
  • 4,090 Answers
Did you use chkdsk/f ?
It might also depend on what your system was formatted to was it NTFS
Ctrl alt del is not unusual to be called after running DOS fixes, unless this is a loop
Thanks for using FIXYA
Posted on Nov 20, 2009
  • dennis bullard Nov 21, 2009
    well it would be a final solution to the problem But it would depend on whether that is what you want to do.
    Go into msconfig Startup and see if personal settings or Chkdsk is set to run on boot.
    START RUN (type) msconfig ENTER and check startup and applications before you go to the drastic
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
A disk read error occurred, press ctrl+alt+del is showing when I open my laptop, please help...iTS the same problem even if i press ctrl+alt+del. thanks!
1. It is possible that your hard drive is faulty and have bad sectors or unable to read due to cable error or motherboard.
2. Try to re-seat the hard disk and if that doesn't work go to repair shop and get it checked, if problem is found ask them to recover the data if you need it and if possible.
3. Get a new hard drive.
Apr 04, 2011 | ASUS K40IN Notebook
Hello, While trying to boot up, I received the message, "disk read error occurred. Press ctrl+alt+del". The same message appears after I press ctrl+alt+del. What can I do to resolve the issue? Thank...
This is called a disk error which generally means your disk has failed. You need to get your data off it if it is not backed up. You will have to replace the disk.
A local computer shop might, just might, be able to install it into a second computer and read the data. The more you fuss with it the lower your chances of getting any data off it.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Dell Dimension 4500 PC Desktop
MY LAPTOP WONT GO TO THE START MENU
you need to click ctrl+alt+del hit cancel and it will work :)
Jan 17, 2010 | Toshiba Satellite M55-S135 Notebook
Disk read error alt+ctrl del restart
load optimal or fail save setting then check if it eliminates the problem if it didn't work. reinstall the ide cable of your hard disk check if it eliminates the problem if it also didn't work back up your hard drive for important file, delete and create hard disk file system, partition and reformat your hard drive if this also didnt work replace your hard disk.
Sep 14, 2009 | Microsoft Windows® XP Professional Full...
Restart Error: "A disk read error occured Press Ctrl+Alt+Del to restart"
Turn the pwr off for 5 minutes
turn the pwr on and tap the F8 or press the F8, 8 times
and select safe mode and do a system restore
Jun 01, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
1- Press and hold the power button on your computer box/case/tower until it shuts down. 2- keep tap/click on "F8" botton while turning you computer on. 3- A black option with some text on it should appear 3- choose Safe Mode 4- go to "My Computer" and right Click on "C" drive and choose Properties 5- go to "Tools" then click "Check Now" button in the "Error Checking" box 6- tick "Automatic ..." then click "Start" 7- Click Shadule and restart your computer. 8- Do not click any thing utill teh utility checks your system If you still have the same problem then it means that you have a virus Download AVG Antivirus if you dont have antivirus program. Now restart your computer and do the step 2-3 and run your antivirus program to search for all "files and folder". Link to download AVG Antivirus: http://free3.grisoft.cz/filedir/inst/avg75free_488a1157.exe
Oct 09, 2007 | Compaq Presario sr1403wm AMD Sempron 3000+...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
