Question about Freezers
Freezer won't get cold
When I transported my freezer I layed it on its side in the pickup. The freezer is about 30 years old. It was that way for about 20 minutes. The freezer won't get cold now. What can I do?
  • klcampbellba Nov 20, 2009
    can a tech come out a fix this by flushing? I would like to keep using this freezer if at all possible
    President:
  • 1,891 Answers
Oil is in the cap tube .due to the laying it down . and maybe in the evap . it may never work properly again . let is sit for a week then start it up in a warm area. wish you luck ..m m
Posted on Nov 20, 2009
  • dennis dodge Nov 20, 2009
    let it set for a week / the oil may get back ( down int the comp. ) don't rush this . and it may solve the problem . m m
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
Jan 19, 2012 | Amana Freezers
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Hi I bought the freezer from the UK and it was fully working. I shipped it to my home country and tried to stsrt it but it was not working
DURING THE TRANSPORTATION IT MUST HAVE BEEN LAYED ON ITS SIDE, NOW YOU NEED A QUALIFIED SERVICE TECH COME AND CHECK YOUR FREEZER SORRY
Sep 13, 2011 | AEG Freezers
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Can i transport the freezer on its side for three hours so it fits under my tarp of pickup will it hurt it
as a general rule, no. Laying it on it's side can cause the oil in the compressor to flow into other parts of the systems so when you turn it on, it may damage the compressor. The general rule of thumb is, if you should do that, you should not run the unit for at least 24 hours. This should, but not for sure, allow the oil to flow back to the compressor. I've never heard anything good from anyone who's ever done this.
Sep 03, 2010 | Danby 4.7 cu. ft. / 133 liter Upright...
Need to transport older Kenmore upright freeer
I would not lay it down but if you can get around it lay it down so the compressor is at the bottom. DO NOT TURN ON FOR 24 HOURS AFTER STANDING UP.
Apr 17, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
Feb 15, 2010 | Whirlpool Freezers
Freezers Logo
130 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
