Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Control board assembly (internal - not front panel)
Our WD-52525 TV can no longer be controlled except for volume. I would like to get the internal PC board for control. Can someone give my source/part#/price?
  • 24 Answers
Try reseting the remote.....hold down the power 00, or 01....then release the power button......Or maybe the parental control is engaged...........On this model all the boards are interconnected in one shielded unit.....That a certified experienced tech wouldn't want to dis-assemble/reassemble in the home.
Posted on Jan 11, 2008
I have a panasonic th42px60u my problem is that none of the controls work except the on and off volume is on but unable to increase or decrease the volume. What part do I need to buy to fix the problem,...
Good day Mr.Daniel Navarro..
The picture below is the sample 42" plasma TV (internal parts)..
If your TV won't adjust volume or change channel by pressing button on the front panel..The problem could be the digital control board,it is the one that have a rectangular red on the image shown..
But before you replace the board make it sure that the control button assembly is properly connected on the said digital control board ( no loose connection or loose solder)..
Also try this remedy:
If you have remote control you can use it for the mean time to adjust the volume and channel so that you don't need to replace the digital control board..
Hope it helps..
Thanks for using fixya and purchased my service..Please don't forget to rate my answer..
Nov 23, 2011 | Panasonic Televison & Video
The timer light green blinking all the time
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD-52525
first unplug and let it sit for a couple of hours and then try again.
Jan 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 projection TV volume control
Check owner / operator manual for "panel lock" selection or
go through menu pages until you spot it........
This selection is made so guests or children cannot operate tv.
In case this suggestion fails, you might try hard reset = unplug
AC cord overnight,then try again...........T.
Nov 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Television Model # WD-52627, Serial # 107108 - TV Not Responsive
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Aug 18, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
