Question about TruTech PLV16190 Television
PLV 16190
  • Anonymous Jan 23, 2008
    no picture
  • shark1611 Apr 08, 2008
    Right in the middle of a TV program the screen went black. Cannot get it to work now.
    Problem Solver:
  • 11 Answers
Yery likely there are blown capacitors in both the low voltage section of the power supply and in the backlight inverter circuit. There may also be a blown fuse in the backlight inverter circuit. Unless you are tech savy and able to use a soldering iron, this repair is best left to a technician.
Posted on May 09, 2008
My picture went out but I was still able to here the audio. I unplugged my tv and plugged it back in and it worked. If this problem is similar to yours and you have not tried unplugging and replugging give it a shot.
Posted on Feb 10, 2008
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV-55WHD1 picture too dark
It may be the lamp itself, some will dim just before failing.
Average life is 2000 hours or two years for OEM lamps and much less for generic ones.
Dec 22, 2012 | Sanyo PLV-55WHD1, PLV-65WHD1 Projection TV...
Looking for a POA-LMP76A lamp and price
Call Encompass Parts 1-800-638-3328 and Look on E-Bay under Electronics.
Feb 14, 2010 | Televison & Video
No picture on TV
check LCD connector or video cables.
May 30, 2009 | TruTech PLV1615T 15 in. LCD Television
Picture has green tint
This is most likely an issue with the cabling. Check that all the cables are inserted correctly and display a picture you are familiar with. Try "wriggling" the connectors as you view the image to see if there is a poor connection.
The problem could be that one of the LCD's is dying and thus affecting the hue.
Nov 10, 2008 | Sanyo PLV 60HT Multimedia Projector
Mod. # PLV16190 can you help me fiend the LP1619 main board ,PLV1619-02-01 , C33-PL1619w101, MP000806A thanks tec. H.A.O*Su.
What is wrong with your TV?Red standby light is lit,but the TV doesn't turn on?Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to,as well as the board that goes to the screen that lights up the bulbs.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.Please let me know if you have any questions.Thank You very much!
Sep 14, 2008 | TruTech PLV16320 Television
Device level repair of the blue lcd device. Not a user repair. The blue device has or is failing. Happens about 3-4000 hours of projector life. Its called color decay. Suggest replacing with a dlp brand product.
Jun 22, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo plv z4
look in the projector menu ( should not be backwards) and switch the view to front projection. It might be set in rear projection. That is what my viewsonic PJ-558 projector can do sometimes
Jan 26, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLV-55WM1
Hi I read your problem with the Sanyo PLV-55wm1. It sounds to me like a power supply problem. Like most new electronics devices, they use a switched mode power supply (SMPS)to supply the voltages to the rest of the set. Many of them use a current feedback loop to sense a short in the circuits that it powers. I would check for a shorted diode in the high voltage section of the tv. If any one of the components is shorted around the high voltage circuit, The current control line will be zero forcing the regulator to shut down.
Mar 25, 2007 | Sanyo AVM-1909S TV
TruTech PLV16190 Television Logo
83 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
