Question about Refrigerators
I have a Kitchen Aid SuperBra Refrigerator where the ice maker is not producting ice howeve there is water. I noticed from the back of the refrigerator that the tube going from the wall to the fridge has water but the specific water tube that goes up to the ice maker is empty?
  • 6,784 Answers
HI. This will occur if the solenoid based valve is not operating correctly. this solenoid based inlet assembly may be damaged, due to a mechanical breakdown within the solenoids structure. I would recommend to test the valve. if it fails the inspection, simply replace it.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Nov 20, 2009
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
We have a kitchen aid refrigerator and we hooked up the copper water line. The water comes thru the door but it is not making any ice. We need to know if there is something more we need to do so that the...
First the white plastic tubing is the supply line inlet for the water to the ice maker. It should be connected to a water supply somewhere in the kitchen. This line goes inside the refrigerator to some relays that turn the water on and off to the ice maker. You will have to check these relays for proper function and depending on the year of your refrigerator will depend on where these are located but most of the time at or near the bottom in the back.
Also there should be a large filter on the back of the frig. check to see if that is clogged. This is the easiest to do first.
Sep 23, 2010 | Refrigerators
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Ice maker is frozen in a kitchen aid side by side
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
