Question about Marshall Music
OD2 Volume control very noisy
If I move the control either with or without (especially w/o) the guitar connected it's almost an explosion type sound even with volume set on low
  • Marshall Master
  • 5,603 Answers
If you can open the unit and put some CRC226 into the control it MAY quiet it down.
The CRC226 is available in the electrical department in a small spray can with a spout. Can is blue color and about $2.80
Posted on Nov 20, 2009
  • Fred Yearian Nov 20, 2009
    Available at Home Depot electrical dept.
Its a marshal 8080 valvestate 80 v and it buzzes and some of the knobs crackle when turned,
Buzzing could be normal for this amp, especially if you have the gain cranked way up (or the volume way up) see if the buzz goes away when you turn the gain/volume down. If not, there is a problem that needs to be properly diagnosed by the amp tech at your local music store. The crackling is also unfortunately rather normal for an amp that's a little older. Oxidation builds up inside the knobs and makes that noise as you turn them. If it only happens when you change settings I wouldn't worry about it, but if it gets bad, a tech guy can clean it out for you.
Feb 20, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have a Fender Deluxe Active Jazz Bass thats makes this really really loud buzzing earthy sound. It seems to happen spontaneously, in fits and starts, but particularly if the cable input on the bass is...
This sounds like either a bad guitar cable or a bad jack in the guitar. Possibly your friend is not as qualified to find these intermittent problems as needed? These jacks are really junky and often have riveting of the barrel come undone... especially if the retaining nut is overtightened. The LONG barrel like jacks are notorious for failing. You have all the information you need to solve this problem. First try a different guitar cable... (often they are broken or intermittent at the end where they flex). If that doesn't fix it, replace the jack in the guitar. Also verify that the conductive coating paint within the guitar is grounded. Sometimes the contact to it is destroyed when the volume control shafts or jacks become loose and they depend upon the shaft barrel to ground the paint.
Jan 30, 2011 | Fender Deluxe Active Jazz Bass Electric...
My Line 6 Spider II 210 won't make any sound from the guitar. When the amp powers on, the speakers pop a little so I know they are connected right. All of the lights are on and the channels can switch...
Bad soldering, especially around the jacks and plugs. Crack in the circuit board. Bad switch contacts on the headphone jack... all these are first things to check.
Here is your service manual for the unit:
http://elektrotanya.com/line6_spider_15w_ii3012_1508_sm.pdf/download.html
Jan 14, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
I have the LR baggs Element Active VTC in my Seagull. It works fine, except when I plug it into the PA system at church. There is a windy, rumbling-type sound that happens whenever the volume knob is...
In the first place you CANNOT connect your guitar directely to the snake ! You must use a DI box to convert the unbalanced output of the Baggs to balanced (differential) drive to the snake using either XLR or TRS cable. The DI should be driven as a HIGH impedance in and using "ground lift".
If the pots are noisy, lube sparingly with CRC 226 available in the electrical dept of Home Depot in a spray can with spout for about $2.70. Spray using the spout into the side where the leads go into the pot.
The volume pot is overly sensitive because you are overdriving the mixer at the other end. The trim on that channel of the mixer probably has to be reduced as well.
Dec 23, 2010 | L R Baggs Eas Element Active Acoustic...
Marshall jvm 410h i'm getting loads of feedback when i use od1 or od2 orange or red mode
Dampen the strings of your guitar. If feedback disappears, then you need to move the amp so it can't resonate the strings of the guitar. OD1 and OD2 WORSEN the chances of the feedback into the strings. When this occurs you can often see the strings vibrating without the player picking them.
Nov 22, 2010 | Marshall Amplification Marshall JVM Guitar...
On clean channel when 'channel volume' is adjusted, the sound cuts out, goes completely dead. I have to switch to another channel and back again or switch off and back on. The amp seems to get confused!
When it is working, wiggle the channel volume control WITHOUT rotating. If the sound cuts out, likely the soldering of the pot leads is broken where it attaches to the board. Try resoldering the connections.
SOMETIMES the control is damaged in which case it must be replaced.
Aug 30, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
I have a fender guitar amplifier, and I can't get any low volume out of it. At level 1 on the dial the volume is sooo loud - no gradual increase at all. It's impossible to play softly. What's going on?
It sounds like (pun intended) the volume pot just needs to be replaced. A good pot is worth about $5 and then you just need to solder it in. That tends to be the tricky part if you can't solder. It takes longer to heat up the iron than it does to do the job. I'd assume this happened either after it had sat for quite a while or after a move.
What can happen is the wiper or the resist inside the pot breaksor even the wire to the pot breaks and there goes your volume control. Depending on what model of amp you have you don't want to run it like this for too long. You can't fix the pot but you do need to replace it. I would assume it sounds like it is either full on or doesn't change the volume at all.
This is one of those maintenance things you should check for from time to time. you may notice that the pots get noisy or inconsistent for a while and then they do this kind of thing.
The attenuator will kill the volume but that doesn't actually fix the problem you have. When the amp is running properly you should be able to get quite a low volume. If you need to run it harder so that it gets into the distortion range then a attenuator will drop the volume down to a practice at home non eviction volume ;-]
May 03, 2010 | Music
My guitar volume won't turn off
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened.
2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
Sep 19, 2009 | ESP Ltd EX-50 Electric Guitar
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
70 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
