Question about GE JE620 Microwave Oven
All elements of display are on. No button beeps or does anything . I have a space limitation on my boat and I can not get a replacement for this model.
    Brigadier General:
  • 4,090 Answers
I would think the touchpad is faulty. Sears will have a replacement pad. The whole case has to be removed to gain access to the pad which plugs into the main board. Bit fiddly but can be a DIY. New pad is about $60-80
You might be able to bargain down a repair for a $100 if you remove it and take it into a service centre for GE
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
  • 106 Answers
Sounds like the computer board took a surge. If unpluging it for and hr dose not clear it , it will need a new board. Were you on dock power or on board gen. or running a 12v to 120 converter. Some thing may have over powered or the hertz were wrong. Over seas 220v converters can screw up the chip on the board. Try 908 757 4245 for parts
Only three buttons on the touchpad work,#1,7 and clock
try e spares for replacement pad e spares.com
Apr 20, 2015 | Microwave Ovens
NO DISPLAY, BUTTONS BEEP PEB1590DM2WW BLANK
Can you still use the microwave? It's probably the control PCB that needs to be replaced.
Sep 19, 2013 | Microwave Ovens
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Beeps twice upon releasing any button and does not do anything... What could cause this and is there a fix?
The problem is in the keypad control board, or smart board. Consideration should be given to replace the microwave oven, because the cost to repair can not be justified.
Apr 06, 2012 | Microwave Ovens
Electricity is on because the colon is showing. But we can't set anything, clock, power, etc. . Cannot program anything. Beeper is beeping for two short beeps around every half hour--.
Hello. Try this. Push the clock button. Then enter the time in hours and minutes, THEN push the clock button a second time. Joe
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Oct 05, 2010 | Danby DMW753 Microwave Oven
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
Stuck on but no power
it is the problem of the faulty heating element .the heating element needs to be replaced to solve this heating problem.
Dec 29, 2008 | Microwave Ovens
GE JE620 Microwave Oven Logo
37 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
