Question about Nintendo Wii Console
No wii screnn, no controller sync
My wii screen dosn't come on and there is no controller connectivity
Please Help somebody
    Scholar:
  • 90 Answers
Have there been any power issues recently in your area?
If so, there may be a problem with the surge protector inside the wii's AC adapter.
Unplug the adapter from the wii and the wall. You should also disconnect both halves of it. Let it sit disconnected for 30-60 minutes. Plug it back in and make sure all connections are correct and plugged in completely.
If that does not fix your problem, please try a different outlet.
If you are still having problems, contact Nintendo for more help.
You can reach them toll-free:
1-800-255-3700
You can also use online support:
http://www.nintendo.com/consumer/
Posted on Nov 20, 2009
    Sergeant:
    Champion:
  • 212 Answers
Try to replace clock battery. It is in small bay on bottom. Should be a 3 volt cr2032 battery. Good Luck.
Guitar syncing on softmod wii
Hello. you must first check that the batteries are good. then, check if your wii is working properly. if both don't help then you must get a wii or guitar!
Jul 29, 2012 | Nintendo Rock Band for Wii
Console does not respond to all remote actions, ie no cursor on screen,only the minus , home , and plus buttons work i have tried several remotes and changed the sensor bar.
I would try to re-sync the controller to the console.
1. Power on Wii
2. remove battery cover from wii remote; press sync button on remote, will cause LED's on remote to blink.
3. Press the sync button on the console (it is located in the memory card holder on the front of the console)
4. The remote is connected once the LED stops blinking. The lit LED indicated what player # the connected controller refers to.
If you are still having trouble then delete the configuration info first and then re-sync the controller to the Wii.
Do this by holding the SYNC button on the console for 15 seconds after turning the unit on (once you see the health and safety screen). After you do this you will need to re-sync the controller individually.
It also warns of bright light sources like sunlight near the sensor bar, highly reflective surfaces (mirros, etc.) behind the sensor bar, sources of infrared radiation (portable heaters or fireplaces) or radio interference from cordless phones, cell phones, etc. as possible causes of interference. See pages 22, 32, 34 of your Wii owner's manual for full information, or call 1-800-255-3700 if you are still having difficulty.
Dec 31, 2010 | Nintendo Wii Console
Wii remote won't connect to the wii console
Here is what I went through, hopefully it will save you some time.
The first thing I did while the Wii was turned on was that I tried to sync the Wii Remote by pressing the "1" + "2" buttons at the same time. The lights at the bottom of the controller flashed for about 30 seconds, but never received the signal from the Wii. Bummer.
The next step I followed was to hit the sync button on the Wii Remote (Wiimote). Then immediately opened the cover for the opening where the SD Flash card goes and pressed the sync button on the Wii. 30 seconds of flashing, and no result. Double bummer.
Finally, after some Google searching, I found a couple of message boards where people had to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. I performed this step and then pressed sync on the Wii Remote. The 2nd controller synced up almost immediately. What a relief!
Apparently the problem lies in the fact that the Bluetooth technology being used has to be manually synced in order for it to connect to the Wii. It does not make much sense at all. You would think they could be pre-authorized in order to minimize time and ease of use. In addition, you really have to be careful that your other controllers are turned on while syncing or else the controller that you are trying to put on channel 3 might end up on channel 2! This happened to me on one occasion.
Good luck with getting your Wiimotes in sync with your Wii. Hopefully this helped!
Apr 18, 2010 | Nintendo Wii Console
I am having probelms getting the board to sych with the box please help !!!!
Simply turn on your Wii. Using the first player remote press the home button then go to the bottom of the screen and you'll see the controller sync screen. You should then see like a resync or something similar. Hot that and the Wii will make two ringing sounds. When this happens press and hold the 1+2 buttons on the remote and then after it connects press and hold the sync button on the Wii Fit board where you insert the batteries.
Feb 01, 2010 | Nintendo Wii Fit for Wii
Our wii controllers are not reading the screen and when they do it wont stop blinking through screens..help please?
Try synchronizing your Wii-mote to your Wii. Open the battery compartment on the remote and the SD card door on the front of your Wii. Press the red SYNC button on your Wii and then on the controller. You know it is synced when a solid LED light is shining at the bottom of the Wii-mote.
Jan 24, 2010 | Nintendo Wii Console
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Second guitar for wii guitar heto will not sync
start the guitar hero game as you normally would. then take the remote that you are going to put into the first guitar and press the "home" button", this should bring up a screen that will allow you to connect another remote in the game, press the reconnect area and aim both remotes at the sensor and press the 1 and 2 button at the same time, exit this screen and then got multiplayer section of the game and you should be set. my 10 year old neighbor had to show me this. good luck..
Dec 28, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
131 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
