Question about Dell Latitude E4200 Notebook
Dell E4200 screen problems
My screen on a dell E4200 has started developing vertical lines - if I squeeze the screen below the lines HARD, the lines disappear temporarily. DO I need a new screen - and can I do that myself?
The screen seems rather plastic-like and flexible. Is there a better-built super lightweight laptop I should consider.
    Brigadier General:
  • 4,090 Answers
Sure there is its called a TOSHIBA
Dell is the poor mans brand and is poorly made to the poor price!
The lines are caused byt a failing Liquid crystal display gel. A new screen can be purchased from a Dell outlet. But you could be spending money on a bettr unit that is reliable and under warranty. Take a ook at the Toshiba L300 range, very affordable, losts of bells and whistles and much better quality. and about $5-600 on special for introduction to the market. These units are usually in the $900 and over range
Please rate my help++++Thanks for uisng FIXYA
Posted on Nov 20, 2009
Hello, I have a Dell U2711 monitor that now displays just a bright white screen. I was using the monitor, when it started getting brighter and developed a series of vertical lines in a repeating pattern...
Dell technical support number by dial Dell helpline number 1-80-243-0019 to get Dell customer support services to repair Dell Computer, Laptop, Printer.
Apr 14, 2017 | Dell U2711 27 inch LCD Monitor
Screen ban vertical
Sir
Press Alt+Con +up arro/down arro/side arro
Or
set screen resolution 1024*768 Check it
or
LCD problem
Oct 07, 2011 | Dell Latitude E4200 Notebook
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
When typing on the E4200 the lcd screen starts to go dim is this a know problem
Check the battery & also see if it happens when plugged in to the a/c adapter.
May 04, 2010 | Dell Latitude E4200 Notebook
My dell l e4200 has screen problem, when I boot it up nothing is showing even if I press fn-f8.
There can be several reasons this is happening. The first thing I would suggest is testing the video card by connecting an external monitor to the laptop. If that works, the cable connecting the laptop screen or screen itself may have been disconnected/damaged/gone bad. If it doesn't work, the video card may have gone bad.
Apr 08, 2010 | Dell Latitude E4200 Notebook
Our week old Dell Studio 17 has developed a background screen which lies below all other normal displays. It's primarily red, thin vertical lines spaced about 5/16'' apart with 3 rows of small dots in...
Hello. Your Dell is under warranty. Just go to the Dell Support Center icon on your computer and email Dell directly. They are wonderful and they will talk you through the fix. Regards, Joe
PS please rate my answer. Thank you!
Jan 04, 2010 | Dell Studio 17 Laptop
I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
Dec 25, 2009 | Dell Inspiron 2200 Notebook
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Vertical lines on LCD monitor
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Sep 14, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell Latitude E4200 Notebook Logo
625 people viewed this question
Alun Cox
