Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
No sound I have a sharp aquos and I turned it on and there is no sound. Yes, the volume is turned up, and it's not muted. Help????
    Genius:
  • 1,112 Answers
Have you checked your Menu in Audio mode to make sure internal speakers are not turned off. Or that you are not in external sound mode. Also Sharp has previous problems with sound board mounting in the chassis as the heat sink strip on the main audio ic touches the metal sheilding and causing audio board to fail. Check with Sharp for updates and service bulletins to your model, they my repair this at no expense to you.
Posted on Nov 20, 2009
Does this tv have an option to set a timer to turn it on?
spec sheet here
http://files.sharp.ca/Downloads/ForHome/HomeEntertainment/LCDTVs/SpecSheets/LE650_SERIES/LE650%20Series_Spec_Sheet_rev.pdf
It does have a Sleep Timer as most do. Not many people want the television to switch on when they are not at home?
Direct Button Operation
INPUT .......................................................... 20
Changing Channels ...................................... 20
Changing Volume ......................................... 20
MUTE........................................................... 20
Sleep Timer .................................................. 20
manual is here
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/mon_man_LC70LE640U_LC60LE640U_LC52LE640U_LC70C6400U_LC60C6400U_LC52C6400U_LC80LE633U.pdf
Sep 22, 2015 | Sharp AQUOS 60" 650 Series LED HDTV -...
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
NO SOUND ON FRONT SPEAKERS OR HEADPHONES VOLUME SHOWING ON SCREEN INCREASING
Make sure the sound isn't muted or directed to the optical out connection.
Oct 07, 2011 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Have picture no sound did a reset nothing
The reason you have pictures and no sound might be as a result of a sound IC or that the volume is too low or on mute.
First check the volume to see if it is okay or on mute then correct that but if it is not, then it is a faulty sound IC that is causing it, so try to dismantle the television and replace the sound IC.
Then the television would be in good conditions once again.
Take care
Oct 11, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I cant adjust the volume, mute the tv or turn it
The IR-Infra Red sensor could be bad. Pretty cheap part. try shopjimmy or partstore. And well the obvious, are the batts good... Hope this helps...
Jun 29, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
No sound
On your remote you should have a mute button. Or some will cancel mute when you press volume up or down. Make sure you are using the TV remote and not the cable or dish remote.
Jul 18, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
327 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
