Question about Toshiba 50H72 50" Rear Projection Television
I'm having the same flickering issue with my Toshiba 50H72,
I'm having the same issue with my Toshiba 50H72, constantly flickering, like a power problem, however, it almost completely clears up when I switch the input to a HD input.
Any idea what I can do to fix it?
Is there some part that I could replace to fix this?
I don't want to buy a new set yet, if it's a minor repair.
Thanks, Larry
  • Philip Frye
    Philip Frye May 11, 2010
    Larry! Has this done this flickering in the past on a non-HD source or channel? Blessings, A/V Media Guy
ctf1800
  • 4402 Answers
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Posted on Dec 11, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 50H72 50 in. Rear
possibly the STK392-110 ic's? it seems like it is the vertical convergence.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
SOURCE: toshiba 62hm195 repair issues
This may sound obvious but did you check to make sure that your lamp access door is properly secured? The set will not power up if the door does not contact the micro switch. Also double check all of your internal wire connections. You may have inadvertently forgot to reconnect a cable or not fully seated one. I know I was guilty of both errors at one time or another while I was working on mine.
Posted on Aug 21, 2008
SOURCE: Wavy Lines which clear up after being on for 10 minutes - Toshiba 50H82
It will cost about $300 to fix. The Hyperboard has to be replaced. I had it repaired over 2 years ago and it works great.
Posted on Sep 25, 2008
SOURCE: violent shaking picture initially but slowly tapers off but still shakes
i have a 50h82 with the same problem as above,please help,billy
Posted on Oct 07, 2008
Power but no picture
the Y-SUS BOARD is for picture in tv.if the picture is not coming or not proper the Y-SUS board needs replacing .but if the picture is blurry or with linings reparing helps.but in your case the tv does not turns on with y-sus board connected only error led comes on.this means y-sus board needs replacement.
you can get it from www.partstore.com
if you are not familiar with replacing the y-sus board its advisable to get it done by local tv repair technician familiar with your brand/model.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Oct 26, 2009 | Toshiba 50H72 50" Rear Projection...
Toshiba lcd tv flickers after being on 15 mins.
This is likely a power problem. Have the power brick checked by an electronics tech to see if it is cycling off and on over time. If the power supply is not the problem, you should consider returning it if you can.
Nov 19, 2017 | Toshiba 32HL66 32 in. LCD HDTV
Need resister
DIgikey should have it. It is a 2Ohm 1 watt resistor.
Feb 08, 2009 | Toshiba 50H72 50" Rear Projection...
Red & Blue lines on screen
stk392-110 i think mine was made in 2002 and i also had to replace mine
Oct 26, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h72
STK392-110 Convergence ICs you will need two of them. You can get replacement ICs with free instalation instrcutions at the following link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba convergence issue model # 50H72
looks like this is your problem http://www.fixya.com/support/t348123-toshiba_50h72
Mar 22, 2008 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72
Just finished one of these here at the shop. There is a service bulliteen from toshiba on these. There is a series of 11 16 microfad service mounted caps on a cuircit board called the hypermodule... basically the main signal processing board. that needs to be replaced. very very tricky soldering. very dificult repair. We charge about 250 in labor pluss the parts
Mar 04, 2008 | Toshiba 50H72 50" Rear Projection...
Tv problem
I just serviced this model, same problem as noted. I did a resolder job on the power/drive PC board. This was NOT the problem! The problem acts like an electrolytic capacitor issue or horizontal drive amp. Once I get my hands a service manual & schematics, we'll resolve it. I'll post my results AFTER Super Bowl.
Rick Macy
BC Electronics
Macy41@aol.com
Dec 18, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
