Question about Dell Latitude D600 Notebook
HI While installing Vedio driver is trowing RPC server unava
HI While installing Vedio driver is trowing an error RPC server unavailable
    Scholar:
  • 56 Answers
Hello sans_sankar,
If it says RPC server is unavailable, that has to do with your internet connection.
Check if both ends of your ethernet or USB cable are properly plugged in their ports on your modem or router to your computer.
You can also turn the modem or router off for a minute then turn it back on again.
Your video installation should be complete, otherwise, it might be incompatible with your computer.
Hope that helps.
Yours truly,
Art Pena
Posted on Nov 20, 2009
SOURCE:
Hi, I encountered in this " RPC server is unavailable " on my laptop when I entered my password. So I cannot access my laptop. Hope for your help.. Thank you.
Possible causes of the "RPC server unavailable" error include the following:
  • Stopped RPC service: If the RPC service on the server isn't running, the client obviously won't be able to reach it.
  • Name resolution issues: The RPC server's name may be resolving to the wrong IP address, resulting in the client contacting the wrong server or attempting to contact an IP address not currently in use. Alternatively, the server's name may not be resolving at all.
  • Traffic blocked by firewall: A firewall or other security application on the server, or a network firewall appliance between the client and server, may be preventing traffic from reaching the server on TCP port 135.
  • Connectivity issues: The client may be unable to reach the server at all due to a general network problem.
Sep 16, 2018 | Computers & Internet
Rpc server error installing driver
Hi. Have you try to install the printer in other pc ?. It seem to be a pc software error
Feb 10, 2018 | Canon Office Equipment & Supplies
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | HP LaserJet 1020 Printer
Cant install driver with "rpc server is unavailable" and also shows both the se and se sec family in device manager.
INFORMATION SOURCE CREDITS TO >>
http://ezinearticles.com/?How-to-Fix-RPC-Error-When-the-RPC-Server-is-Unavailable&id=3298701
Have you gotten an RPC error lately? They look a little like this:
- "RPC Server is Unavailable"
- OR "The RPC Server is too busy to complete the task"
- Here's the best one, "Access denied"
This is fun stuff. Unfortunately, an RPC error is one of the most common errors out there, and most of us don't even know what RPC is.
What is RPC?
RPC stands for "Remote Procedure Call." This probably still doesn't tell you much. Let's see if we can put this in non-technical language. RPC is the go between of your computer and server. This is what allows your computer to access a network.
RPC has two main parts to it: the client and the server. When the client (the program requesting something) sends a message to the server (the process that takes the order or performs the task), it is being asked to execute a certain procedure. The client waits for the server to process the call before resuming the execution.
Why Won't the RPC Server Work?
Usually, the RPC error pops up because there is some sort of miscommunication between the computer and the server. Most of the time, the wires get crossed somewhere due to Internet components that are not configured or activated. Sometimes it is just a matter of adjusting the Internet Firewalls or Proxy Server.
Quick RPC Error Fix
One way to investigate an RPC server error is to verify that you have enabled the DCOM Tunneling is enabled and not being blocked by any third party Internet Security programs such as AVG, Norton, McAfee, etc.
To do this:
1. Go to Start and Run
2. Type in DCOMCNFG
3. Click on Component Services
4. Click on Computers
5. In Computers, right click My Computer
6. Choose Properties
7. Go the Default Properties tab
8. Check the "Enable DCOM" tab
9. Go to the Default Protocols tab
10. Click Add
11. By the Protocol Sequence move the down arrow to Tunneling TCP/IP
12. Click OK
13. Click MoveUp button until Tunneling is at the top of the list
14. Now you may select SPX and Remove
15. Click OK or close the program out
16. Restart the computer
When You Need Help with the RPC Error
The RPC Error is such a common error, it seems like it should be easy to fix. However, the DCOM Tunneling fix is only the beginning of troubleshooting an RPC server error. The good news is that you really don't have to do anything when it comes to an RPC error if you maintain your computer with registry maintenance tools. Try researching the benefits of a registry cleaner to fix RPC errors.
Optimize-Your-PC, with its Advanced Registry Cleaning Technology, will repair an RPC error, and Speed Up Your PC, all in under 2 Minutes.
ALSOP TRY DHCP CLIENT RESET
Jan 21, 2010 | ATI RADEON 9200 Graphic Card
Driver not getting installed - LBP2900B
where i can find driver for
Canon LASER SHOT LBP2900B
Jun 13, 2009 | Canon LASER SHOT LBP-2900 Printer
I am trying to install the canon selphy ES20 printer...however when I attempt to add the printer to the computer, it does not recognise it and says there is an error with installation and "RPC server...
Hi, this is a solution for you. Follow the steps below and your Canon printer should be working.
  1. Unplug the printer from your computer
  2. Download and install the drivers from this link
  3. Plug in you printer and just let your computer recognize it and do it's thing.
Good Luck!
Greased
Jan 31, 2009 | Computers & Internet
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Jan 29, 2009 | Brother MultiFunction Center MFC-440CN...
My HP 3920 deskjet printer not printing.
the service needs to be turned back on altho I dont recall where u do that. Try a search on your pc for services... then turn the print spooler back on
Sep 16, 2007 | HP DeskJet 3930 InkJet Printer
"The RPC server is unavailable"
I?m assuming this is happening on a Windows machine. This is one of the really vague error messages that Microsoft give for an incredibly large number of problems. I typically see this on servers but have seen it occur on workstations. If you?re running XP, 2000 (server or Pro), or 2003: - Check and make sure your Remote Procedure Call Service is running. - There is an older vulnerability that tries to use a flaw in the RPC services. It is fixed if you copy of Windows is up to date so make sure it is. - Review your application log for any clues. If you need more assistance let us know your operating system, if it is fully patched and what is showing in your log file around the time you receive the error message.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
Dell Latitude D600 Notebook Logo
137 people viewed this question
Ekse
Clive
Clive
