Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
The color on my wesinghouse is distored everything looks green HELP
    Sergeant:
  • 295 Answers
Have you tried a full removal of the AC power. If you have and it still is doing this. Try a differnt source such as a DVD or VHS input. It would be good if you had one of these connected to see if it's image is also green.
Note: what color are the TV's menus when they display.
Normal or green also.
If they are normal then it's a processing board issue. If the menus are green also then it's a LCD panel issue. Both aren't cheep to fix.
Blessing,
A/V Media Guy
Posted on Nov 20, 2009
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv pic has redbluegreen images pic distorted
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
Dec 10, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Color has strong green tint - can't adjust with set-up program
One color plug in the back was unplugged - Since the TV had not moved we didn't think to look for that. The cable bundle must have been bumped causing the problem - I feel a bit silly that I hadn't looked for that. Thanks for your follow-up.
Jun 12, 2009 | Panasonic TH-42PX60U Television
Green color
The blue color channel has failed. There are many types of faults than can cause this. In some cases it may be a simple connection from one of the cable assemblies, but not often.
If there is a failure, the technician will change the appropriate circuit boards to fix the fault.
This type of fault can be expensive to service.
Jerry G.
Jan 22, 2009 | Olevia LT37HVS 37 in. LCD HDTV
The screen turns green
Bad main board (scaler board),.
Jan 11, 2009 | Vizio L32 32 in. LCD HDTV
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Distored red picture
sometimes a nearby speaker or cassette recorder or an old telephone may affect it, because of its magnetism power ,take away any nearby stuff and try manual reconvergence after a short power off for a reset ,
Apr 30, 2007 | Samsung HCM4215W 42" Rear Projection...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
112 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
