Question about ViewSonic VX2235wm LCD Monitor
Monitor will not power on. All of the connections
Monitor will not power on. All of the connections are intact. Initially monitor would display a number of various screens with different colors and patterns.
  • 235 Answers
Yes all the connection are intact, in these cases have the cpu check the monitor is not the problem, the monitor is still displaying which means that it is good, have the cpu check or check how many vga adpater is present in the cpu, if you have a built in and a separate card and you plug the monitor to the built it will not work and you need to connect it on the separate expansion card that is install inside your cpu
michael
Posted on Nov 20, 2009
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
My monitor power light is on but no display it is under warrenty
Hi and welcome to the site,
Initially, consider an experiment. Shine a flashlight at an angle towards the screen with the monitor and computer both powered on. Note if a dark/ghostly image of the desktop could be seen. If yes, then it would be a backlighting issue. In most instances, it would be the inverter that provides high frequency, high voltage supply to the CCF (cold cathode florescent) lamps.
It is a hardware fault and not a setting nor a configuration issue.
Offhand, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of warranty).
Good luck and thank you for asking.
Aug 10, 2010 | ViewSonic VA1912w 19" LCD Monitor
Power led on.but no display
If all the connection are intact and yet you still get blank page, then, The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 27, 2010 | Proview PS 709 17 in.CRT Conventional...
All I get is a white screen
Is the power led button on while the screen of your monitor goes white and as it been displaying before?
If it as, have you check all connection to see if the VGA and all other connection are intact and well connected? if you have check all this, and yet, it is still white screen you get while the power button is on, it means your picture board is bad.
It means the picture board of your monitor has develop fault and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | HP w19 19" LCD Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
Change power output from motherboard
Windows will automatically install your desktop monitor using generic drivers. But if it doesn't, go to safemode by pressing F8 before it goes to windows. Change your settings from there. Also, normally, CRT monitors can take more than LCD monitors.
Sep 08, 2008 | ASUS V8440 (128 MB) Graphic Card
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
ViewSonic VX2235wm LCD Monitor Logo
90 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
