Question about JVC AV-32FA54 32" TV
Picture is slightly tilted
The TV works fine, but the picture is slightly tilted. Is there an adjustment to center the picture so it's not tilted anymore, like you'd be able to do on a computer screen?
    President:
  • 1,284 Answers
Its an easy adjustment but it requires you to work around the deflection yoke on the neck of the picture tube. Above the yoke is a red connector that is carrying 30,000 volts then on the yoke itself you have wires that are connected to the horizontal and vertical circuits that can carry up to a 1200 volt pulse. So this alignment is not for anyone but a technician. I personally would leave the tilt until you can have a technician touch it up for you. Take a moment to rate my answer. Thanks...
Posted on Nov 20, 2009
Picture is slightly angled on my 73 inch dlp.
I would suggest two possible reasons: first the mechanical adjustments are off or out for tilt----rare but can happen.
The most common reason for this is the set is not sitting completely on a flat stable surface; if one side or both are not on a perfectly flat surface the picture will tilt; you can always see this effect if you grasp one side of the set and pull up/down and or twist the cabinet a little.
The set may (a few models do) have a tilt adjustment in the customer menu.
The mechanical adjust should only be attempted after the other possible causes are ruled out.
Let me know if you have questions.
SDT
Nov 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Mitsubishi WD 62725 -picture slightly tilted from right to left
Thats a common adjustment called the TILT adjustment. You can get the service manual emailed to you from the following link which will explain how to doo the Tilt adjustment. Heres a link to the proper manual for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/wd52525-dlp/cName/mitsubishi
Jul 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tilted picture on screen
Tilt correction under setup menu use up down buttons to adjust and center * button to save setting
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Colors off
Set all convergence controls to center and then manually set all tubes to as close as possible to coincide with each other. Then, use those electronic potentiometers to fine tune the picture.
Dec 06, 2008 | RCA P60920BL 60" Rear Projection...
GE Television Dark Shadows
If you are comfortable working inside the set, I can suggest the following:
1) Open up the back and locate the flyback transformer (part with large red wire coming out the top). There should be 2 adjustment posts on the back of it.
2) adjust the top one slightly clockwise as you are facing ht back of the TV. This should cause the overall picture to brighten. Don't turn it too much as you will then see the "retrace" lines.
3) Adjust the lower one to focus the picture.
That should help a bit. If not, then the picture tube is probably at the end of its life. Keep me posted with your results.
Dan
May 24, 2008 | Televison & Video
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
Hitachi Standard T.V.
Some of the problem could be a weak or damaged picture tube - especially if it encountered rough handling in the move. Other possibilities are bad capacitors in the power supply and deflection circuits which are common with this aged set. No adjustments come to mind that could permanently fix these symptoms.
Feb 11, 2007 | Hitachi 27UX01B 27" TV
JVC AV-32FA54 32" TV Logo
100 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
