If you force to pull out the paper while the printer is on, then theres is problem with your printer, in every printer there is small motor that run all the roller inside the printer if there is paper jam and you pulled out forcefully while printer is on then that is your problem you need to have it fixed or replaced
Usual thing is forcing paper out SOMETIMES tears a small piece off which OFTEN jams in the paper feed sensor of the printers.
It is often hard to see this, so get a bright light and look for that or similar things. There are often several phot-electric sensors that can have paper shreds and shut the printer down.
