Question about Hitachi 55VS69 55" Projection HDTV
I have a blue hazy halo around the center of my screen
    Brigadier General:
  • 4,090 Answers
5VS69 is a LCD rear projection set---if you have blue or some other color discoloration in some part of the picture most likely you have a damaged optical light engine. This model used two different ones--It is an expensive part as one wholesales for about $550 and the other about 600 not counting major labor to replace. If you have an extended warranty--get it in and fixed. The reason this happens in some sets is the Lamp used for the light source creates a lot of heat and can damage the lens/baffles inside the sealed light engine. Blue is the most common as that part of the engine is usually closest to the lamp. The set shines the light from the lamp into the engine and signal etc is injected and at the top of the engine is a 3 inch lens that projects the picture into a mirror which puts it on the screen. Some of Hitachi's earlier sets are now involved in class action lawsuits as they had a red oval in the middle of the screen--red was first in those models--some Sony and other sets have had the same Sorry I cvannot bring you better news! Thanks for using FIXYA
Posted on Nov 20, 2009
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
55VS69 is a LCD rear projection set---if you have blue or some other color discoloration in some part of the picture most likely you have a damaged optical light engine.
This model used two different ones--It is an expensive part as one wholesales for about 550 and the other about 600 not counting major labor to replace.
Some of Hitachi's earlier sets are now involved in class action lawsuits as they had a red oval in the middle of the screen--red was first in those models--some Sony and other sets have had the same problems.
Let me know if you have questions as I am here to help. I know I am not giving you good news but based on your description I think it is your problem.
If this has helped you at all, rate this solution as I do this here for FREE.
Thanks for using Fixya!
SD TECH
There is a hazy 'glow' around any bright colors on my screen
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 25, 2011 | Philips 60PP9352 60" Rear Projection...
Convegence
Yes - about every 4-5 years.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Televison & Video
7P5441 C101 54in color is wrong
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Philips big screen hazy/color problems easy fix?
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
You can see some example photos and find a solution here...
Nov 28, 2009 | Televison & Video
The picture looks hazy and anything that is white has a certain glow to it
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 04, 2009 | Philips 51PW9363 51" Rear Projection...
Excessively bright whites...has a haze around any white items. all other colors are fine.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
May 12, 2009 | Televison & Video
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Yellow tinted halo
you need to have the lcd pannels cleaned
Feb 26, 2007 | Hitachi 60V710 60" Rear Projection HDTV
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
116 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
