Question about Motorola Mobility RAZR V3
Voice memory full message ...
When I power on the phone and try to use it the above message comes on. My phone was working properly up until now. I've recharged it, removed the battery and sim card for a little while, still nothing. Also when I press any key I get the same message, so I can't get into any of the phone functions to reset the phone. I tried using the USB cable to flash it but I am not sure if I did the procedure correctly. Also there is no red button indicator in the phone hopefully that will help. I've read a lot of reviews on how to fix the problem but I am not sure what to? Phone is little over a year old, no warranty and I'm not ready to throw in the towel on this unless I have to. Your help is greatly appreciated. Thank you.
This solved my problem of my Razor V3 keypad repeatedly giving a voice record memory full error message:
1. Purchase at local hardware a precision tool with star bits (I bought a Husky HD-74502W at Home Depot for $6.00.
2. Power off phone.
3. carefully remove the screws on the inside cover of the LCD panel. There may still have the rubber plugs which you can remove carefully with a toothpick. Be careful not to pop it off and lose it though (they're small!)
4. Take a flat head and pry the LCD panel off the back cover. You may notice that it is filled with all kinds of crud, dirt.
5. Use compressed air (all purpose duster) and blow the dust and dirt from the connections.
6. There are two flat circuits at the bottom of the hinge which connects the keypad to the screen. This is where I found the problem. On the gold circuit, there is a tiny latch, carefully lift it up. I used a tiny needle nose plier to detach the connection to clean it with canned air. I noticed it was full of dust.
7. Carefully place back in the gold circuit connection and close the tiny latch to secure it.
8. At this point, I powered on the phone to make sure it would work correctly. The hellomoto graphic should come up when powered up. If not, you didn't put the connection in correctly.
9. You may have to clean the other connection as well. If all is good, reattach cover and screw back in.
9. Thanks for all the past troubleshooting. I hope this helps keep another Razor from the harzardous waste dump.
Posted on Jun 29, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 95 Answers
Your voice messages sometimes get saved but dont reflect for you to read, try and call voice mail no and listen to all the messages as you delete them also, a hanging incoming voice message may be the problem so unless you empty your voice mail box you cannot do anything.
Posted on Jan 14, 2008
    Problem Solver:
  • 11 Answers
That is really some good problem i also suffered from it what i did to get rid of the problem was that i turned off my phone took out the memory card .
Then i restarted the phone and again turned it off and then put the memory card and turned the phone on again and then i saw that phone was working properly might this work for you.
Posted on Jan 12, 2008
Sony ericsson k800i states operation failed when i try to open games
Operation failed" is an error message that occurs when the phone has got a problem with it's GDFS. Your phone sounds like it's very poorly. You say you've tried a master reset? Can you tell me if that was reset settings or reset all? I had the same error message on my k850i when trying to get into my SMS inbox. A full master reset resolved it.Can I also ask that you remove the memory stick when you try a full reset and don't put it back in until you've tried the phone again?
You cannot get viruses on these phones, so we can safely rule that out.
Mar 01, 2012 | Sony Ericsson Cell Phones
Hi there i have a problem in my Nokia 6600 when i've tried to read my msgs and also goin to my contacts the screen shows System Error (-25) what should i do
There are times that this system error comes from memory. try to remove it first or replace another memory card and test.
if this problem keeps on showing,just format or reset your phone by doing this Hard Rest;
1. turn off the phone, remove simcard and memory card.then put the battery back
2. long press ( * ) ( 3 ) ( call key ) simultaneously then power it on. (keep holding the three buttons) wait until the formatting message appear (you can now released all buttons) wait until the process is finish and it will restart automatically.
* Be sure battery is in full charge when doing this method
* also back up all important files before doing so.
Good luck...
Jun 26, 2011 | Nokia 6600
My answering system will not accept any new messages. It says the mailbox is full. All of the messages have been deleted and it reads 0 messages. What can I do?
delete all kinda old messages...voice messages recorded..sms...if it is a cell phone ...and all that it is keeping memory full...after that it may not be the cause of the messages but a short memory in the phone and you filled it with photos or mp3..or other stuff if it is a cell....this will make space and it will be ok ...you do not have to delete all ..just a few to make some space ...
it is possible that the photos and other media keeps the memory filled and not sms and other messages ...in fact the voice messages and the emails usually are kept on the web ...just media files and sms in the phone memory ...
in the future if the phone accept a memory card get one for the media and leave the phone memory for messages...
Mar 07, 2010 | Cell Phones
Parrot V5 10C device tells me memory full when trying to pair
The unit can only hold 3 phones in memory. Hold down the answer and hang up buttons together for 2 or 3 seconds and you'll hear a voice telling you memory is being erased. It's ready for 3 more phones again.
Aug 24, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Motorazr V3 Status indicator no longers displays envelope for voice messages
Why am I receiving a memory full notification? space.gif space.gif answer.gif Memory full warning notifications are shown once the SMS memory reaches 80% full, which is 80 out of 100 SMS.
The notifications show up every time on receiving a new message. On reaching 100%, "Memory full notification" message is shown and no new messages will be received until we make space for incoming messages by deleting some from the inbox.
Memory full warning notices are shown only if "Auto Erase Inbox" is set to Off in Messaging settings (Menu -> Settings -> Messaging).
If set to On, then these notices are not shown. By default this is set to Off.
Oct 22, 2008 | Motorola Mobility RAZR V3
Voice record memory full & screen froze
Are you able to get into the software to purge the voice records?
If not, it sounds like the phone needs to be "reflashed" at an authorized service centre. Take it where you bought it. It should not cost you if it is less than one year old (warranty).
Sorry I couldn't be more helpful.
Feb 08, 2008 | Motorola Mobility RAZR V3
Messages say resend all the time in d outbox
This is not a question of your phone's external it says for internal or workable memory of RAM. RAM is for providing room to running application. In your phone RAM is seems stuck and you have to empty it by formatting. For that backup your data and reset your phone by entering code string *#7370# and it will work again properly.
Jan 12, 2008 | Nokia 6630 Cellular Phone
Try to text message, but it says the memory is full
are you useing a memory card? the internal memory isnt that big. try eracing some pictures contacts ect
Jan 03, 2008 | Motorola Mobility RAZR V3
Voice memory full
what you need to do is
go to
settings
master reset - default 000000 security default
master clear - default 000000 security default
Dec 31, 2007 | Motorola Mobility RAZR V3
Memory Full?
I unplugged my power supply cord from back of phone and replug it again, I found there were in fact four messages. After I deleted them I was able to use the memo button again. So perhaps this willhelp you, too. Ackey320
Jul 26, 2007 | GE 29897GE2 Corded Phone
Motorola Mobility RAZR V3 Logo
277 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
