Question about Sewing Machines
Bernina Aurora 430
I have a fairly new Bernina 430 machine with embroidery module. While working on an embroidery project, I had a thread break. Fixed it and rethreaded the machine. Now the machine will complete 45 stitches and then I hear the "broken thread" alarm again and it stops. There's no thread break, though. Does this every 45 stitches. I called the dealer and she said to check a spring on the take-up arm. I did that, but it didn't help. Any ideas? Thanks,
Joyce
  • 8 more comments
  • SunshineS Feb 02, 2008
    I have the same exact problem with my aurora 440. Of course it happens on a Friday night when I need something for tomorrow! Have you been able to fix the problem?
  • monogrammom May 11, 2008
    I have the same problem. I was using the embroidery module turned the machine off, came back later to pick up where I left off. I received the thread breakage alarm...but no thread breakage. I have called several dealers asking for help. I was told to check the spring arm and did that. It will sew without the alarm but not embroider without alarming. It will stitch properly. It is just very time consuming and frustrating. Can anyone help?
  • Anonymous Jun 17, 2008
    Have the same problem, my tech told me to look for thread or fuss in the tention disc. It would work for one or two colors then start again. I will be taking my machine in with an example this week. Will post if smothing is found.
  • idee1 Jul 16, 2008
    I have exactly the same problem with my Aurora 430. I am quite sure that threading has been done correctly. Anyone a better solution?
  • tonipup Jul 27, 2008
    I have a fairly new Bernina Aurora 440 machine with embroidery module. While working on an embroidery project, I had a thread break. Fixed it and rethreaded the machine. Now the machine will complete 45 stitches and then I hear the "broken thread" alarm again and it stops. There's no thread break, though. Does this every 45 stitches. I called the dealer and she said to check a spring on the take-up arm. I did that, but it didn't help. Any ideas? Thanks,
    Diane
  • kag10898 Sep 14, 2008
    I've got this same problem and its driving me nuts. Has anyone managed to solve it? I've practically dismantled the machine but to no avail. The bloody thing still keeps stopping
  • Sistie1 Nov 19, 2008
    I posted the original message about this problem and finally figured it out on my own--it is the threading that causes it, and not the bobbin thread--at least in my case. If you refer to the diagram on page 9 in the manual, the problem occurs at Step B. When you bring the thread alongside the needle thread take-up cover and down under it, pull the thread up firmly before going up and over to Step C. You will feel the thread engage inside the bottom of the cover. If you don't feel that, your machine is not threaded correctly and you will get that annoying alarm every few stitches. Hope this helps someone!
    Joyce
  • susanpi
    susanpi Sep 27, 2012
    Has anybody found a solution to the broken thread issue.
  • Amie Richards Feb 15, 2013
    Here it is three years after these posts and I'm having this same problem every 45 stitches. It's not the way it's threaded because I've re-threaded with differeent spools, different bobbins, cleaned out the bobbin area, checked inside the thread area, the whole nine yards. Has anyone found a better answer than that it's the way it's threaded? Seems like a computer problem more than a manual problem?
    Here it is three years later and I'm having the same problem. Since it's every 45 stitches, its seems more like a computer problem. I've changed the thread, the bobbin, cleaned everything, etc. It doesn't seem to be a threading issu. Any find a solution yet?
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
Posted on Mar 29, 2008
Bernina 440QE, when I'm using the embroidery module, the machine stitches for 36 stitches then says there is a thread break when there is not, how do I resolve this issue.
there could be a sensor problem, if the machine continues to have the problem then having the machine checked would be a good idea
Feb 19, 2015 | Bernina Sewing Machines
Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
  • Service Pack 2 for BERNINA Embroidery Software V5 (V5.0W)
  • Aurora driver for 64-bit Windows® operating systems
  • Latest dongle driver
  • EConPC 3.1 & ADX 7.14
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
Jul 04, 2010 | Bernina Artista 180
Bernina aurora 430 calibration problem
The complete manual is available at:
http://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/aurora/Manuals/032907-52-04_1103_a430_a440_a450_EN
A reset can be done as follows:
press the clr button. The altered stitches will be set to basic when you turn the machine off
May 21, 2017 | Bernina Artista 180
When stitching the design the upper thread keeps
The tension is not properly set for embroidery, try to rethread totally new. Sometimes it is also caused by broken thread inside the machine, you can open it with the supplied L-shaped tool on the left side of the machine where the lamp is located and than take it out with a tweezer.
Dec 21, 2009 | Bernina Artista 180
Aurora 430 Bernina
Hi, possibly your feedogs are dropped and in the darning position and/or its thinking you want to embroider and there is NO hoop attached or entire embroidery unit plugged in. Check your feedog button below the handwheel on the bottom.
Rick
Jul 29, 2009 | Bernina Sewing Machines
Using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Apr 06, 2009 | Bernina Sewing Machines
430 will not recognize wembroidery unit.
I am the person who posted the solution about too much stabilizer. Unfortunately that did not solve the problem in the long term. I spoke with the Bernina dealer and found out that the sewing machine needed to be recalibrated. I found out how to do this from my user manual and the problem appears to be solved for now... hope that works for you
Jan 12, 2009 | Bernina Activa 140
Embroidery
I had the same problem. It maybe you have some bits of thread caught inbetween the metal plates . That's what my problem was . Try cleaning carefully between the plates with something flat carefull not to scratch them.
Feb 25, 2007 | Bernina Artista 180
Sewing Machines Logo
1,535 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
