Question about Dishwashers
Whirlpool ADP951,not operating
Moved to a new house that has a whirlpool ADP951, very old. It wont do anything. The green light flashes. When I first ran it it seemed to run for a short time and then stop. The water stayed in the bottom. We sponged it out and now it wont start at all? The green light just keeps flashing, Can you help?
  • 776 Answers
My advice, go buy a new one. If money is tight, go to the clearance aisle at Home depot and look for a scratch/dent discount model to replace it.
Old dishwashers were never good from the beginning. No point in fixing it - it was never designed well.
Posted on Nov 20, 2009
Testimonial: "Yep yep yep, that is what I thought too!"
  • scuadra79 Sep 02, 2011
    We had the same problem right now in our washing machine and were very confused. When green light start flashing it means previous washing program hasn't end so you have to keep the green light button hold for few seconds and then it comes back to normality and you can start a new washing program (washing time). Always when machine is working let it finish sometime it takes breaks during the washing that doesn't mean dishes are ready
Have a whirlpool dryer with 3 wire plug moved into house that requires 4 wire plug. Have new plug, just not sure how to connect it
attach the red,black and white wires on new cord to the terminal block and attach the green wire on the cord to the cabinet their should be a green screw very near the terminal block but if not attch the green wire onto the cabinet on a spot near the block that looks something like this
_____
___
__
Jul 22, 2011 | Whirlpool WED5300S Electric Dryer
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Try to heat oven, get 'P5H' message on display
the START pad begins any oven function. if the START pad is not pressed within 5 seconds after pressing a function pad, the Push to Start ["PSH"] indicator light will flash and the push to start tone will sound as a reminder. you can download a manual for your range at www.whirlpool.com, go to "owner center", scroll down to "manuals & literature" and enter your model number
Aug 16, 2009 | Whirlpool GSW9800PW Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
I have a Whirlpool dishwasher model ADP951. the green light is continually flashing and will not run, help with this would be most appreciated.
Have a look underneath dishwasher by removing front bottom access panel, the one touching the floor. Look for a round plastic disc about size of 4 jam lids together, centre front of dishwasher. Inside of it is a foam disc that will float up off the base of the dishwasher if water causes it to do so. This floating up will trip a switch. Clean base of dishwasher of water and maybe test the switch with multimeter. Reset fault by holding down start button.
Apr 26, 2008 | Whirlpool Dishwashers
Whirlpool ADP951 modulogic - not working
try holding down the on button for three seconds and sometimes it will complete the cycle. ours doesn't start the whole time. check your water regulator valve under your sink, as it may be leaking which may cause the problem, in the process of replacing mine, but can't find the psi value
Apr 14, 2008 | Dishwashers
Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Dishwashers
Moved and now my comuter wont do anything
Try reseating the memory.  I have moved computers and 9 times out of ten the memory came loose.  So just take out the sticks make sure they're not too dusty then put them back in.
Oct 16, 2007 | Compaq Presario 5000 PC Desktop
Dishwashers Logo
249 people viewed this question
Top Dishwashers Experts
