Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Picture goes black with no warning, must turn off
Picture goes black with no warning (audio still OK), must turn off TV for 5-10 min. Problem has been recurrent and it is getting worse. It looks that when you turn on the ceiling fan, it helps a little bit, but still no guarantee. It happens watching movies, or cable, or playing videogames. HELP!
  • 732 Answers
San_chanoc, Yes, and it will get worse, and eventually not work at all because you don't know how to fix a possible "COLD SOLDER JOINT" on a printed circuit board. The unit's "switch-mode-power-supply", that supplys most of the unit's DC voltages could have developed a THERMAL INTERMITTANT solder joint that will only need to be reworked to restore reliability to the unit once more. The problem will be in finding it!!! You may need a large magnifying glass or industrial 10x-20x inspection microscope to find the ONE and only ONE faulty Frosty looking thermally FRACTURED solder joint. Check out youtube!!! It's all there for you to view. But don't fix the problem if you find it. Get a 3meg pixal or better digital camera that can do close-ups (1-2 inches) to document the EVENT and send it to Sharp and ask them to PAY you for the repair. Yes, it will get worse due in part to the GASES in the AIR we breath will continue to cause more OXIDATION of the hairline fractured joint. Well, good luck on your quest. I hope that this has given some insight into your problem. Let us KNOW what you find out!!! lmistyrel@ aim.com or 12fixlouie on fixya Bye for now.
Posted on Nov 20, 2009
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
Kenmark 20" LCD TV Sound but no picture
My Kenmark Tv Switches its picture off if the PSU voltage drops. Audio is OK but picture does not return as PSU voltage goes back up. PSU's are about £10 online !2Volt 4A Might be worth a punt
May 04, 2009 | Zenith IQC50H95W 50" Rear Projection...
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
263 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
