Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My toshiba MW27F51 has horizontal white line on the top about two inches from the top. how do i get that out?
hardrocko
  • 1476 Answers
SOURCE: Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Posted on Jul 13, 2006
megatronix
  • 57 Answers
SOURCE: white horizontal lines at top of picture
Yes, definitely worth fixing. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor (no more than USD4.00 in price) usually gets it working perfectly again. If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Posted on Jan 18, 2008
  • 4 Answers
SOURCE: Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Posted on Jun 19, 2008
SOURCE: White lines accross top of screen on our 27 inch Toshiba,
My Toshiba required replacement of two of the vertical filters/capacitors. Doesn't take long and the parts are inexpensive, but requires a repairman.
Posted on Sep 12, 2008
  • 6 Answers
SOURCE: Toshiba 27
Check for open capacitors in vertical output circuit I believe 47 uf.
Posted on Aug 31, 2009
Horizontal white lines across top of screen. About two inches from the top, some channels more pronounced than others but always there.
Check for dry electrolitic capacitors near the vertical Ic output maybe one of 50v to 100mf or 50v to 10mf
Jul 24, 2010 | Toshiba 27A43 27" TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
VERTICAL HOLD NOT WORKING PICTURE TUBE HAS HORIZONTAL LINE
OK below is a service manual to download, this is what engineers use to troubleshoot and repair.
http://elektrotanya.com/toshiba_mw27f51.pdf/download.html
May 05, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
WHITE LINES
Replaced C407 100uf/35V Vertical section.
Mar 03, 2008 | Toshiba 27A33 27" TV
Toshiba MW27FN1
That problem is in the vertical section. Check for leaky or dry capacitor(s). Check the capacitor(s) with values less than 50uF.
Good Luck.
Jan 20, 2008 | Toshiba 24AF41 24" TV
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
312 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
